Many people who are new to tuning the PCM of their car for performance has been lead to believe that the VE tables MUST be changed to get a proper tune.
As they say the more a lie is marketed the more it becomes true.
This causes hugh problems for people learning how to tune their car and are further confused by the vendors who make tuner products claiming you MUST use their product because other brands cannot do VE tuning.
If you stop and think about this whole subject and learn up on how OBD-II powertrains function then you know the VE function was a left over from the old days when powertrains did NOT have a MAF and went by the MAP values and then used statice values in VE tables as what MAYBE the amount of airmass volume was getting into a cylinder.
VE todays purpose is used when engine is started because the MAF is not flowing airmass and is used as a backup system if the MAF was to fail.
Its also used when coming off a lift of gas pedal and is only used when engine is less then 4,000 RPMs.
This means then the VE values are NOT what the engine functions from for most engine conditions.
Since its totally ignored above the 4,000 RPMs then it clearly has no effects on power enrichment or WOT.
So lets do a testcase. We used our 1999 LS1 Corvette which is stroked to 372 CI ( 6.1 Liter) thus cylinder volume is different then stock, it also uses the 2001 and newer intake manifold, uses the larger 85 mm Z06 MAF, has headers and the heads are ported along with a 3rd party CAM using 40 lb/hr injectors.
Now with all those changes and the STOCK VE table values still being used you then have to assume if the HYPE of VE tuning is true then this car should run like crap.
Using the Ease scanner which collects 40 frames a second of PCM data we did a daily driver test run collecting over 40,000 PCM cycles to assure we had a fair look at most engine conditions of what the airflow was versus what the statice VE table values are.
Keep in mind this was done in 40 degree winter weather, the engine compression is 11.3:1 and elevation is around 4,000 feet above sealevel ( which also would impact airmass)
This testrun collected over 33 meg bytes of PCM data !
Results :
As we see the LTFTs are perfect around zero, so are the STFTs, zero knock or misfire and O2s reporting for part throttle just under 0.500 mVolts which is just about 14.1 AFR ( recall the 4,000 feet)
Being there was almost no WOT in this testrun the corrected HP was still 465 and still saw a maximum of 45 lbs/min airflow so if the VE myth was true then this powertrain should be reporting poor performance and OBD-II values
BUT its not !
Now if we let the PCM and OBD II scanner show the facts we see below 3 tables
Bottom is the GM static VE table values
Top table is the reported air volume to cylinders and center table computes by percent the difference in what was in realworld airmass verus the stock VE values. Positive percent values is more airmass then the VE tables values and of course negative values means less air was taken into cylinders then the VE table values.
We can see in some cases a hugh percentage differences thus if in fact the VE tables were so important to engine functioning properly then the car performance and even how well if functioned overall would be quite bad, but its not because in the end its exactly what GM states that VE function is NOT used for most engine conditions and thus blowing your brains out trying to tune for a VE driven engine is a total waste of time in most cases.
