After 2 days of PCM relearn is a testrun with at least 35,000 PCM recorded cycles of data and the computed true airflow and then a difference to the new VE table values.
Keep in mind values below 25 KPA MAP are from lifting on gas pedal thus PCM is reducing or turning off injector flow and that the PCM will not even use the VE tables above 4,000 RPMs
