Without hard data I can only make a guess that during WOT its too lean and when going back to EPA mode the O2s are reporting lean so PCM is adding fuel
Yes, but that would cause a short fluctuation of the fuel trims, right? In my case they stay negative during several minutes.
or maybe COT is kicking in or the tune at those RPMs when leaving PE mode has a fuel flow or VE values incorrect
COT is disabled (maybe that's not a good idea...) VE are stock.
Also could be a temp issue and PCM temp tables are forcing PCM to go rich but if it clears up within 10 minutes of drive time its not a big deal.
You mean the coolant temperature? the fans are set to keep it 195 - 210F.
I suspect the high IAT is driving this issue and why I suggest our water/meth injection kit since it reduces IAT about 40 degrees. That nozzle should be of course right before IAT so it can see that colder airmass
The nozzle is installed after the blower, about 10" before the IAT. During WOT the recorded IAT remains around 80F.
There is no intercooler and it's true: the PCM sees hight IAT values in certain situations (slow traffic, engine at idle during long periods).
I just don't see how to change the relationship IAT/fuel in open loop using LS1Edit.
I only have a fuel adder for WOT (which in my case is set to 0 for IAT>50°C).
Maybe the popoff valve where it is in the path is effecting airmass or is leaking and sucking in hotter air ?
The Vortech kit recirculates the air: the MAF is installed before the blower. Because of the recirculation the air becomes hot when the car isn't moving (it picks up the heat of the engine bay). Is that a good idea to insulate the air ducts?
The air from the bypass valve goes back right before the blower, about 15" after the MAF. ok, maybe it produces some turbolence... but 15" is pretty far away (?)
One other thing is w/meth when its comes on/off cause 02s to report rich and lean and fools PCM for a short time.
I see this all the time after w/meth goes off since when its on the PCM is told fuel trims have gone rich so PCM leans out, then w/meth being off its now too lean and PCM goes to richen up again
I know this situation and the WI ON/OFF points are set to avoid it.
All in all I think too it's a temperature issue (IAT). But so far I haven't discovered how to influence that.
The original Vortech setup had the IAT right after the air filter, so that the PCM always sees fresh air and not the reality.
Here how it looks like:
