You can find that injector as
http://teamzr1.com/injectortypes.html or at the top of forum use seach function for
injector
where I have posted about 40 threads on them
They are 42.29 lbs/hr at 43 PSI rail pressure and 445 cc/min
Yes being the coil of the injector might take xx time to react and open and close then PCM is adding that to the pulse width so that the time that coil reacts then the remainder of PW time would be the correct flow time.
Coil could be faster then what stock was and its offset table values but also could be a slower reacting coil.
The vendor which is Lucas ( I do not use them I do not think they are very good at spraying well as duty cycle increases, nor do I like Racetronic products ) has to be the one who says what that coil reaction time is
