Hi
Thanks for taking the time...
I would expect the system to make around 575 flywheel+ when correctly tuned.
I am running 10psi wastegates with a meth/water injection system (comes on at about 5psi).
Part Number of the injectors is Delphi 01D030B.
I currently have the injectors scaled for the 58psi fuel rail on the LS1. This gave me a flow rating of 48lbs/hr (or 6.18gm/sec at 100kpa in LS1edit).
Great info on the delay time. I had misunderstood the function entirely...
The engine does hesitate slightly under mild acceleration (which is very irritating). Perhaps a result of the timing issue between spark and injector pulse.
Pulse width at tick over is 2.27ms and then up to 11ms at WOT.
I now have a request into the vendor for additional info on the injectors.
It sounds like I have a combination of issues to resolve with these injectors.
Thanks
Dave
