#7076 - 11/13/2507:26 AMKnow if the gas your using is good or bad
Keep in mind with engines of old and new to be aware of good and bad gas makeups GM designed the gas specs under Top Tier for a good reason
I have suggested due to all the crap in using gas with Ethanol is so simple, easy testing to determine how much percentage of Ethanol your pumping in and how much water it has pulled into the gas tank
