I have the standard Bosch bypass valve supplied in th Vortech kit. I was considering an adjustable valve like the Maxflow (also supplied by Vortech).
Mine is the 6 PSI kit and I was thining the Bosch valve was good enough... but maybe not.
What valve would you suggest?
Before chenging the tables I mentionned I had about 15-20 G/sec while shifting (gas off).
Now it's around 10-12 and it actually shifts better
In the original F-Body program the air values are about 3 times higher than for the Corvette of the same year. I loaded the Corvette tables, included idle.
