Another C8 Model Coming ?
by teamzr1. 07/15/25 02:05 PM
by teamzr1. 07/14/25 10:41 AM
by teamzr1. 07/14/25 05:52 AM
C8 Corvette Wins GT Asia Race
by teamzr1. 07/13/25 03:54 PM
C8 Cop Cruiser is the Winner
by teamzr1. 07/12/25 08:51 AM
by teamzr1. 07/10/25 02:52 PM
by teamzr1. 07/09/25 04:07 PM
by teamzr1. 07/10/25 04:24 PM
Topics3,624
Posts6,737
#714 - 11/24/06 12:33 PM Supercharger and M6 shifts
I was thinking to rebuild my T56 tranny: the way it shifts is (usually) a sign of worned synchros... (slow shifts and gear clash).
Because of another reason I removed the belt of my Vortech SC and noticed how good and fast I was able to shift confused
I think there is a residual pressure between the blower and the throttle body: this "pushes" some air in the engine and doens't allow it to reduce the RPM.
This could be caused by a too small bypass valve, but right now I don't want to modify the system
This is a mechanical throttle body with an idle pintle: is there a way to reduce RPM during shifts modifying the program? Like reducing timing? Or cutting off the fuel?
Another thing I noticed: the F-bodies (like mine) have the idle set at 800 rpm. It is 800 when the car doesn't move, but when I drive (no gas) and push the clutch the engine speed doesn't drop below 1000 rpm. Why? This is not a clutch issue, it's something in the program. Is there a reason? How can I modify that using LS1Edit?
Thanks - Stefano
#715 - 01/05/07 10:04 AM Re: Supercharger and M6 shifts
I find out that Idle Air, Airflow Decady in Gear and Throttle Cracker Airflow influences the engine speed between the shifts (when I let off the gas pedal).
With different settings it is possible to close the idle pintle completely: this avoids residual pressure to enter the manifold, what (in my case) caused too high RPM while shifting.
#716 - 01/05/07 11:11 AM Re: Supercharger and M6 shifts
To me that is the whole purpose of a popoff / release valve when using boost.
I have seen cases where 2 popoffs are required or the size if only using one
I doubt shutting off bypass air via IAC would make that much of a difference.
#717 - 01/05/07 01:00 PM Re: Supercharger and M6 shifts
I have the standard Bosch bypass valve supplied in th Vortech kit. I was considering an adjustable valve like the Maxflow (also supplied by Vortech).
Mine is the 6 PSI kit and I was thining the Bosch valve was good enough... but maybe not.
What valve would you suggest?
Before chenging the tables I mentionned I had about 15-20 G/sec while shifting (gas off).
Now it's around 10-12 and it actually shifts better smile
In the original F-Body program the air values are about 3 times higher than for the Corvette of the same year. I loaded the Corvette tables, included idle.
#718 - 01/05/07 03:39 PM Re: Supercharger and M6 shifts
In almost all issues I have seen with decel and/or idle issues and having boost is either the popff is too small, not installed properly or requires 2 popffs.
Some popoffs only require changing the strength of the spring in it.
1 registered members (teamzr1), 27 guests, and 12 spiders.
The RING - Inside Truth ?
by teamzr1. 07/15/25 06:47 PM
