Topics3,706
Posts6,894
Most Online425 Oct 19th, 2025
#72 - 02/08/01 08:07 PM
'84 and up bulletins
Bulletins for 1984 Chevrolet Corvette V8-350 5.7L
Safety Recalls
TSB Number Issue Date TSB Title 1. 84C25 SEP 85 Axle (Rear) - Differential Cross Shaft/Revised Info 2. 84C22 MAR 85 Product Safety Campaign 84C22 Relocation of Cruise Control Serv 3. 84C02 JUN 83 Front Brake Caliper Bracket Bolt
Service Bulletins
TSB Number Issue Date TSB Title 1. 99-00-89-022 DEC 99 The Year 2000 and Vehicle Electronics 2. 99-00-84-021 NOV 99 Expediting Parts 3. 99-08-42-009 NOV 99 Setting of I/P Dimmer Control to View PRNDL Display 4. 99-06-02-017 OCT 99 Radiator Repair/Replacement Guidelines 5. 99-08-51-007 OCT 99 Refinishing Aluminum Wheel 6. 99-00-89-019 OCT 99 Warranty Parts Center/Corporate Parts Return Program 7. 99-00-01-001 SEP 99 AC Delco Remanufactured Engines 8. 99-07-30-017 SEP 99 Auto/Trans Oil Cooler Flushing and Flow Check Procedures 9. 99-07-30-020 SEP 99 Automatic Transmission Service Procedure Change 10. 99-08-64-016 SEP 99 Use of Silicone for Weatherstrip Maintenance 11. 000000A JUL 99 GM Service Bulletin Precautions 12. 99-03-10-102 JUN 99 Original Equipment Chrome Plated Aluminum Wheel ID 13. 99-08-49-006 APR 99 Cleaning of Upper Instrument Panel Surfaces 14. 99-08-51-001 APR 99 Paint-less Dent Repair Process 15. 99-06-03-002 MAR 99 Battery Insulator Replacement 16. 83-81-34 MAR 99 Operating Vehicle with SIR Warning Light On 17. 99-00-89-002 MAR 99 Using the New GM Service Bulletins 18. 86-05-02 DEC 98 Delayed Warranty Start Process 19. 87-71-74 NOV 98 1-2 Accumulator Piston and Outer Spring Replacement 20. 83-35-08 NOV 98 Chemical Staining of Chrome Wheels 21. 76-02-02A OCT 98 Recommended Axle Lubricant 22. 80-05-03 AUG 98 Redefined Use of Parts Warranty Special Claims B and C 23. 82-05-03 MAY 98 Elimination of Labor Op Z7920/Z7930 24. 82-05-02 MAY 98 Request for Authorization Using Routing Code H 25. 87-61-24 APR 98 Use of Surface Conditioning Discs 26. 83-01-14 MAR 98 VIN Plate Replacement 27. 72-05-09 FEB 98 GM Dealer Empowerment Program 28. 82-05-01 FEB 98 New Vehicle / Replacement Battery Warranty Instructions 29. 73-50-37 JAN 98 Brake Rotor and Hub Cleaning Tool Revision 30. 72-05-14 JAN 98 Enhanced Sublet Repair Policy 31. 72-05-13 JAN 98 Repair/Replace Policies and Procedures 32. 72-05-12 JAN 98 Shock Absorbers and Struts Operations 33. 72-05-07 DEC 97 ACDelco Remanufactured Engines 34. 72-05-11 DEC 97 Rail Dust Removal and Chemical Spotting - labor 35. 71-05-02 DEC 97 Recall Campaign Follow-Up Post Card 36. 73-01-10 DEC 97 Technical Assistance Call Preparation 37. 62-05-02A NOV 97 Labor Operation Z1241 - Personal Property Damage 38. 73-12-13 NOV 97 PureGuard 2 Operating Alert 39. 73-62-13A SEP 97 Servicing of Aluminum Heater Cores and/or Radiators 40. 72-05-02 AUG 97 AC Delco Remanufactured Transmissions 41. 73-62-13 JUL 97 Aluminum Heater Core and/or Radiator Replacements 42. 73-62-14 JUL 97 Approved Engine Coolant Recycling Processes 43. 73-10-54 MAY 97 Two-Part Urethane Adhesive For Windshield Installations 44. 631208A APR 97 A/C Tool And Equipment Maintenance 45. 620504 APR 97 Operating Procedures 46. 731204 FEB 97 Air Conditioning Systems With R12 Or R134a Service Issue 47. 731049 FEB 97 Body Sealer Tape For Collision Repairs 48. 649601 JAN 97 Compact Disk Players Procedures 49. 431207E JAN 97 Guidelines For Retrofit R-12 Vehicles To R-134a 50. 600503 JAN 97 Warranty Repairs And Claims Procedures 51. 62-05-03 DEC 96 Dealer Prohibited Use of Labor Open. and/or Claim Type 52. 310503C DEC 96 Warranty Claim Processing 53. 610111 NOV 96 Key Code Information 54. 668304A SEP 96 ACDelco Service Center Locations Odometer/Speedometer 55. 400501A SEP 96 Corporate Parts Return Program Instructions 56. 636532 MAY 96 Enhanced Emission Inspection Maintenance - Equipment 57. ATRATB334 JAN 96 Delayed Forward Engagement / Burnt 3-4 Clutches 58. ATRATB256A JAN 96 Rear Planet Failure - Lack Of Lube 59. 516547 JAN 96 Revised Tech 1 Cartridge for Oxygen Sensor Test 60. 536507 DEC 95 Enhanced Emission Inspection Maintenance - Update 61. 588302A JUL 95 AC Delco Locator Service for Delco Electronics Exchange 62. 570102 JUN 95 Reformulated, Oxygenated Gasoline and Calif. Phase 2 RFG 63. 580101 JUN 95 Use of a Diagnostic Worksheet 64. 531205 MAY 95 Contaminated R12 Refrigerant Testing & Handling 65. 436201B APR 95 Propylene Glycol Engine Coolant 66. 570201 MAR 95 General Information - Dexron® III A/T Fluid Introduction 67. 431218A MAR 95 J 39400 A/C Leak Detector Maintenance Kit Availability 68. 420515A FEB 95 Chevrolet Claim Processing 69. 516502 FEB 95 I/M Emissions Diagnostic Manual 70. ATRATB294 JAN 95 Axle Nut/ Lug Nut Tightening Specifications 71. 436510 JAN 95 I/M 240 Program - Equipment Purchase 72. ATRATB292 JAN 95 No 2nd, No 4th and No TCC - 700-R4 73. 436507 DEC 94 Enhanced Emission Inspection Maintenance Program 74. 435009 DEC 94 Front Brake Pulsation - New Diagnosis and Repair 75. 431048 NOV 94 Adhesive Caulking Kit Revisions 76. 436506 OCT 94 I/M 240 Repairs - Obtaining Technical Assistance 77. 446501 OCT 94 PROM/MEMCAL - Identification Marks 78. 431223 SEP 94 Contaminated A/C Refrigerant 79. 410103 SEP 94 Product Campaign Bulletin Numbering System 80. 330105A SEP 94 Using GM Service Bulletins 81. 149301 JUL 94 Release of Service Package For Nickel Tape 82. 433502 JUL 94 Speed Rated Tires 83. 436505 APR 94 Enhanced Emission Inspection Maintenance Programs 84. 033206 MAR 94 Reduced Power Steering Assist (Cold) 85. 435001 FEB 94 Aftermarket Anti-Lock Brake System Products 86. 310504 FEB 94 Policy - Recycled Engine Coolant 87. ATRATB234 JAN 94 Forward Sprag Design - 700-R4 88. ATRATB265 JAN 94 Rear Planet Failure (Lack of Lube) 700-R4 89. 331226 JAN 94 Retrofitting R-12 Vehicles to R-134A 90. ATRATB201 DEC 93 No Line Pressure Rise - Stuck Pump Slide 91. ATRATB196 DEC 93 Shifts In Manual Low - 700-R4 92. 383001 DEC 93 Steering System Bleed Procedures 93. 306502 OCT 93 How Fuel Economy Is Determined 94. ATRATB179 JUL 93 Late Or No Upshifts 95. 393504 JUL 93 Leaking Cast Aluminum Wheels 96. ATRATB175 JUL 93 No 2nd Gear 97. 349212R JUL 93 Radio Frequency Interference - Identification/Diagnosis 98. 316501R JUN 93 Introduction Of The Fuel Injector Tester Tool 99. 931638A MAY 93 Isolation Diodes Information 100. 9313310 MAR 93 Door Locks Binding or Sticking/Key Hard to Insert 101. 9313110 MAR 93 Rear Lift Window Hard to Open/Hinge Loose to Glass 102. 9358A10 FEB 93 Acid Rain and Rail Dust Damage to Base/Clear Coat 103. 93966C FEB 93 Factors That Affect Fuel Economy 104. 939710 FEB 93 Paint Peeling From Muffler 105. 93774B JAN 93 Differential Pinion Shaft Lock Screw 106. ATRATB134 NOV 92 Bind In Reverse - 700R4 107. 93297A OCT 92 Buzzing Noise At Idle Coming From the 4L60E A/T 108. 93316C OCT 92 Effect of Fuel Volatility On Driveability 109. 93356D OCT 92 Engine Miss, Hesitation or Roughness - Information 110. 93203E OCT 92 Scuff/Scratch Removal From Aluminum Wheels 111. 922501A AUG 92 Use of Alternate Refrigerants In CFC 12 112. 922323E JUN 92 Damage Due to Improper Mounting of Steel Wheels 113. ATRATB118 JUN 92 Valve Body Interchange - 700R4 114. 923310 NOV 91 Acid Rain Damage to Base Coat/Clear Coat 115. ATRATB078 NOV 91 How To Use A Pressure Gauge - Automatic Trans. 116. 92427A NOV 91 Sporadic Transmission Slip, Downshift, or Busy Cycling TCC 117. 913880A AUG 91 A/C Delco Advance Exchange Programs 118. 913846E AUG 91 Damaged and/or Misdiagnosed ECM/PCM 119. 913967A AUG 91 Evaluating Peened Spacer Plates On All A/T 120. 913907A AUG 91 New Output Shafts and Seal 121. 913717A JUL 91 4L60/700-R4 Transmissions Stuck In First 122. ATRATB058 JUL 91 Valve Body Assembly 700-R4 Inspection 123. 913446E JUN 91 State Emissions Testing Information 124. 9133410 MAY 91 Hvlp-High Volume Low Pressure Paint Application 125. 912980A MAY 91 Labor Time Guide Request For Review Updates 126. 912837A APR 91 Automatic Transmission Binding In Reverse Condition 127. 912850A APR 91 Cleaning of Upper Instrument Panel Surfaces 128. ATRATB046 APR 91 Diagnosing Converter Lock-Up Problems 129. 9128210 APR 91 Importance of Checking Clear Coat Thickness 130. 912841A APR 91 Loose or Missing A/C Access Fitting Caps 131. 9041210 MAR 91 Inoperative Power Seat and/or Blows Fuse 132. 873098B MAR 91 Kit For Headlamp Door Actuator 133. ATRATB043 MAR 91 No 4th, Late 4th, Falls Out Of 4th - 700-R4 134. 912356B MAR 91 Use of Recycled Engine Coolant 135. 912136D FEB 91 Parasitic Current Drain Procedure, No Start Condition 136. 912083B FEB 91 Reduced Power Steering Assist At Low Temperatures 137. ATRATB030 DEC 90 Bind-Up On The 1-2 or 3-2 Downshift 138. 911335 DEC 90 Change In Brake Feel After Rotor Refinishing 139. 911268E NOV 90 Chattering Wiper Blades 140. 903727A OCT 90 4L60 Service Replacement Model Update 141. ATRATB028 OCT 90 Engine Testing With A Vacuum Gauge - Auto Trans. 142. 91858A OCT 90 Procedure For Checking Connector Terminal Contact 143. ATRATB024 SEP 90 Harsh Reverse Engagements 144. ATRATB010 SEP 90 Torque Converter Identification 145. 902935 JUL 90 Brake Lathe Produces Poor Brake Rotor Finish 146. 902488B MAY 90 Underhood Lamps Are Inoperative or Stay On 147. 91108A APR 90 Aftermarket Accessories Installation Guidelines 148. 91148A APR 90 Checking For Parasitic Current Drain 149. 902166 APR 90 Prevent Leakage of Small 75 mm Oil Filters 150. 91090A APR 90 Used Anti-Freeze Policy 151. 901996E MAR 90 Revised Chart C-1D, Code 33, 34, 63, 64 152. ATRATB9002006 FEB 90 Automatic Transmission Fluid 153. 901627A FEB 90 New Rear Bushing Removal/Installation Procedure 154. 9015410 FEB 90 Seat Cushion Retainer Wire Service Kit 155. ATRATB9001003 JAN 90 Lubrication Correction - 700R4 156. 909210 NOV 89 Carpet Inserts Become Loose 157. ATRATB8930 OCT 89 Automatic Transmission Math Part 2 158. 90753E OCT 89 Tire Company Warranty Assistance Programs 159. 892680B OCT 89 Use of Gasoline Containing 15 Percent Mtbe 160. ATRATB8927 SEP 89 20 Steps To successful Auto Transmission Repair 161. 892531B SEP 89 CFC Reduction and Refrigerant Recovery Recycling 162. ATRATB8928 SEP 89 Fluid Filter Seal 163. 892625 SEP 89 Light Brake Drag - Brake Switch Adjustment 164. 90568 SEP 89 Packard 32 Way Connector Identification 165. 892583B SEP 89 Steering Gear Intermediate Shaft Torque Specifications 166. ATRATB8923 AUG 89 Automatic Transmission Math Formulas 167. 90496B AUG 89 Reconstituted Anti-Freeze 168. ATRATB8926 JUL 89 ATM Wiring Diagrams Thru 1989 - 700R4 169. 90340A JUL 89 Labor Guide Request For Changes, Feb./June 170. 892037A JUL 89 Proper Usage of Spacer Plate Gaskets In Overhaul Kit 171. ATRATB8921 JUL 89 TCC Lock-Up Delay Valve - 700R4 172. 891976A JUN 89 Camshaft Specifications, Manual Revision 173. ATRASIL8917 MAY 89 New Control Valve Assembly - 700R4 174. 891528B MAY 89 Selection of Correct Wire Insulation Material For Wire Repairs 175. 891271B APR 89 A/C Refrigerant Loss Due to Loose or Missing Access Fitting Cap 176. 891460A APR 89 Goodwrench® Vehicle Security System Labor Operations 177. 891386A APR 89 Revised Procedure - Install or Connect Intake Manifold 178. 891126C MAR 89 Fuel Pump Strainer (In-Tank Filter/Sock) Replacement 179. 891167A MAR 89 New Case Assembly - Removal of 2ND, 3RD, and 4TH Clutch Pressur 180. 891089A MAR 89 Poor AM or FM Radio Reception 181. 89970A MAR 89 Use of Car/Truck Line Indicator In Place of Model Names 182. ATRASIL895 FEB 89 Improved Governor Driven Gear 183. 89900A FEB 89 Labor Time Guide Request For Review Changes - September/January 184. ATRATB894 FEB 89 New Fluid Filter Seal 185. 89855 FEB 89 On-Car Brake Rotor Turning Tool 186. 89593E JAN 89 Cast Aluminim Wheel Porosity 187. 89637A JAN 89 New Control Valve Assembly Elimination of TCC Bore 188. 89316C NOV 88 Fuel Feed and/or Return Pipe Repair 189. ATRATB8847 NOV 88 Kills Engine In Drive And/Or Reverse - TCC Problem 190. 8836510 NOV 88 Media Blasting Sources 191. 8836710 NOV 88 Rusting Fuel Filler Door Hinge Links and Pins 192. 89381B NOV 88 V5 Air Conditioning and Refrigerant System Diagnostic Procedure 193. 883517B OCT 88 Neutral/Drive Manual Transmission Gear Rattle 194. 883405 SEP 88 Disk Brake Noise 195. 883450A SEP 88 Rear Seat Lap/Shoulder Belt Kits 196. 89013A SEP 88 The Importance of Four Wheel Alignment 197. ATRATB8836 AUG 88 Bind Up When Overdrive Is Engaged 198. 883125 AUG 88 Brake Pulsations and Disc Brake Rotor Surface Refinish 199. 882836E JUL 88 Electrostatic Discharge Damage 200. ATRATB8834 JUL 88 Identifying Correct Sprag Rotation - Auto Transmission 201. 8824210 JUN 88 Cleaning of Upper Instrument Panel Surfaces 202. 882456B JUN 88 Engine Cooling System Leaks 203. 882463E JUN 88 Installation of After Market Styled Wheels 204. 872959A JUN 88 Radio Noise "Pop" Caused By Switches 205. 882696E JUN 88 Rough, Unstable or Incorrect Idle Service Manual Update 206. 8826310 JUN 88 Six-Way Power Seat Adjusters 207. 8729210 MAY 88 Painting Procedures 208. ATRATB8822 MAY 88 Solid Teflon® Sealing Rings/Turbine Shaft - 700R4 209. 882077A MAY 88 Sporadic Engagement of Torque Converter Clutch 210. ATRASIL8813 MAR 88 New 3-4 Clutch Apply Package - 700R4 211. ATRATB8816 MAR 88 No Upshift - Governor Contamination 212. ATRATB887 FEB 88 Checking Pressure Switches For Leaks 213. ATRASIL8810 FEB 88 New Lo And Reverse Clutch Assembly - 700R4 214. 8726310 JAN 88 Front Center Air Deflector Damage 215. ATRASIL881 JAN 88 New Iron Pump Rings 216. 8726810 JAN 88 Window Regulator Replacement 217. ATRATB8770 DEC 87 No Passing Gear (forced detent) Upshifts Normal 218. ATRASIL8732 OCT 87 Fluid Leaks/Oil Pump Body Seal - 700R4 219. 87224 OCT 87 Rattle From Turn Signal Lever 220. ATRATB8754 SEP 87 All Automatics - Front Bushing Wear 221. 8856 SEP 87 New Pump Assembly Vane Rings THM 700-R4 THM 200-4R 222. 8842 SEP 87 Service Replacement Electronic Modules (ECM) With PROM Installe 223. ATRASILEXTRA AUG 87 Correction To Service Bulletin 224. ATRATB8748 AUG 87 Metal Sealing Rings - Automatic Transmissions 225. ATRASIL8722 JUL 87 Correction To SIL8722 - 700R4 226. ATRASIL8722 JUL 87 Pump Assembly - Casting Number Information 700R4 227. ATRATB8735 JUN 87 4-3 Downshift/Slight Acceleration - 700R4 228. ATRATB8736 JUN 87 Restricted Exhaust System Check 229. ATRATBEXTRA JUN 87 Service Bulletin Correction - 700R4 230. 87150 MAY 87 Revised ECM Replacement Procedure - Chart C-1 231. ATRASIL8713 APR 87 Auxiliary Accumulator Valve - 700R4 232. 87116 APR 87 Loose Corvette Door Trim Panel 233. 86237 APR 87 Power Steering Fluid Cooler 234. ATRATB8725 APR 87 Updated Input Sprag Assembly - 700R4 235. ATRASIL878 MAR 87 Converter Clutch Solenoid - Fluid Source Identification 236. ATRASIL8710 MAR 87 Down-Shift Clunk In Manual -3- Range - 700R4 237. 8786 MAR 87 Power Seat Transmission Usage and Identification 238. 862226C FEB 87 Engine Surge After A Hot Soak and Short Park 239. 86220 FEB 87 Slipping/Loss of Drive Range THM 700-R4 240. 85219 FEB 87 Upper Quarter Panel Removal and Installation Procedure For Crac 241. ATRATB876 JAN 87 2-3 Flare-up, or Repeated 3-4 Clutch Failure 242. ATRASIL871 JAN 87 Checking Lubrication Passages - 700R4 243. 8758 JAN 87 Transparent Removable Roof Panel Breakage 244. ATRATB8662 DEC 86 Clunk on 2-3 Shift - 700R4 245. ATRATB8661 DEC 86 Diagnosing Internal Pressure Leaks - 700R4 246. 84270 NOV 86 Coolant Sensor Kit 247. ATRASIL8627 NOV 86 Service Procedures - Oil Pump 248. ATRASIL8614A OCT 86 Correction To Service Bulletin - 8614 249. 86185 OCT 86 Corvette Body Repair Materials 250. 86176 OCT 86 Electric Outside Rear View Mirrors 251. 86188 OCT 86 Fluid Leaks From the Oil Pump Body Seal 252. ATRATB8648 SEP 86 Case Switches Installed On Outside Of Case - 700R4 253. 86148 SEP 86 New Accumulator Pistons and Seals For Enhanced Shift Points and 254. ATRASIL8619 SEP 86 Overheating In Fourth Gear 255. ATRATB8647 SEP 86 Partial Tie Up In Reverse - 700R4 256. ATRASIL8620 SEP 86 Production Changes 1984 - 700R4 257. ATRATB8642 AUG 86 Blowing Fuses, Engine Runs Bad; No TCC Lock-Up 258. 86124 JUL 86 1982-1986 THM 700-R4 Transmissions Slipping Condition-Loss of D 259. ATRASIL8613 JUL 86 Harsh 1-2 Shift - 700R4 260. 86117 JUL 86 Power Seat Adjuster-Excessive Movement 261. ATRATB8634 JUL 86 Pressure Tap Locations - Automatic Transmissions 262. 86107 JUL 86 Rear Axle Service Parts Usage and Identification 263. 84265 JUL 86 Rear Hatch Window Assist Rods 264. ATRASIL8614 JUL 86 Shudder In Reverse Condition - 700R4 265. 8696 JUN 86 1982-1986 THM 700-R4 Transmissions New Pump to Case Bolt and O- 266. ATRATB8627 JUN 86 Late Upshifts/High Main Line Pressure - 700R4 267. ATRATB8628 JUN 86 Low Mainline Oil Pressure - 700R4 268. ATRATB8632 JUN 86 Manual Valve Sticks - 700R4 269. ATRASIL8612 JUN 86 Oil Pressure Switch Locations - 700R4 270. ATRATB8630 JUN 86 Passing Gear Spin-Up/Engine Revs Up - 700R4 271. ATRATB8624 JUN 86 Pump Failure 272. ATRATB8633 JUN 86 Reverse Friction (Lined) Clutches - 700R4 273. ATRASIL8611 JUN 86 Service Update - 700R4 274. ATRATB8629 JUN 86 Snap Ring Jumps Out Of Place - 700R4 275. ATRATB8623 MAY 86 Hidden Residue Build Up - Valves Sticking 276. 8662 APR 86 Uneven Wear-Outer Ribs On Corvette Tires 277. 86477C MAR 86 700-R4 Transmission Shudder In Reverse Condition 278. ATRATB8612 MAR 86 Converter Clutch Shudder 279. ATRATB8614 MAR 86 TCC Lock-Up Kits 700R4 - Precautions 280. 8652 MAR 86 THM 700-R4 Transmissions - Manual Update For Elimination of the 281. 8651 FEB 86 All THM Transmissions-Identification Information, Including 3-L 282. ATRATB8610 FEB 86 Pump Break Up - Excessive Regulator Shuffle 283. 8636 FEB 86 Remanufactured Fuel Injectors For (TBI) Throttle Body Injection 284. ATRATB861 JAN 86 Rapid Pump Bushing Wear 285. ATRATB863 JAN 86 Sticking Throttle Valves 286. 8617 JAN 86 Window Regulators 287. 8615 DEC 85 Locks Cylinders - Inoperative/Proper Lubricant Usage 288. 85157 NOV 85 Air Conditioning - DA6 Compressor Assembly Info 289. 85146 NOV 85 Cruise Control (Custom III) - Delay - Misdiagnosed 290. 868 NOV 85 Fuel System - Integrator/Block Learn - Fuel Delivery 291. 85136 OCT 85 Door - Trim Panel Upper Garnish Molding - Available 292. 85111 AUG 85 4 Speed - Direct Drive - Noise/All Gears (AOD) 293. 85107 JUL 85 THM 700-R4 - New Pump Assembly - Service Parts Info 294. 85100 JUL 85 TV Cable - Identification (700-R4 Light Duty) 295. 8568 APR 85 4 SPD - Loss of AOD Operation - Condition Correction 296. 84252 APR 85 Defogger (Rear Hatch) - Blown Fuses/Circuit Revision 297. 85626CVIM APR 85 Driveability Conditions - Excessive Alcohol In Fuel 298. 8561 APR 85 P/S - Rack & Pinion - O-Ring Seal Fitting Leaks 299. 8570 APR 85 Seat Belts - Mandatory Legislation & Extenders 300. 8571 APR 85 THM 700-R4 - Control Valve Assembly - Proper ID 301. 8563 APR 85 THM 700-R4 - Forward Clutch Plate Assembly 302. 8559 MAR 85 Basecoat/Clearcoat Repair Systems 303. 85546VI MAR 85 Minimum Acceptable Oil Levels - Updated 304. 8548 MAR 85 Oil Seal Leak - AOD - Output Shaft & Pump Assembly 305. 8547 MAR 85 Paint - Repair Without Repainting - Procedure 306. 8555 MAR 85 Rear Hatch Window - Trim Panel (Rear)/Rubber Bumper 307. 8540 FEB 85 A/C - Refrigerant Hose & Clamp Repairs 308. 8538 FEB 85 Brakes - Caliper/Knuckle Assemblies - Clearance 309. 8543 FEB 85 Door Ajar Light - Inoperative - Switch Corrosion 310. 84240 FEB 85 Engine Stops When Starting With A/C "On" (A/T) 311. 8533 FEB 85 Rack & Pinion Steering "Short Gear" (RWD) Available 312. 8535 FEB 85 Replacement of the Pump Body Oil Seal Assembly 313. 8536 FEB 85 THM/ATX-Hex Head Screws & Conical Washer Assemblies 314. 84235 FEB 85 Throttle Position Sensor Specifications 315. 8531 FEB 85 Transmission Damage - Roll Pin Not Seated Fully 316. 8537 FEB 85 Wheel Nuts (Locking) - Replacement Procedure 317. 8528 FEB 85 Wheels - Tight Fitting - Procedure For Removing 318. ATRASIL8530 JAN 85 2nd Apply Piston & Housing Applications - 700R4 319. 84232 JAN 85 Brake Pads - Hold-Down Spring Breakage - Replacement 320. ATRATB8514 JAN 85 Erratic/Late Shifts As Unit Gets Hot - 700R4 321. ATRASIL8532 JAN 85 Front Pump - Air Check 700R4 322. 84151 JAN 85 Generator - Noise (Moan) - At Idle With A/C On 323. ATRATB856 JAN 85 Lip Seal Packages - Part Numbers 324. ATRASIL8515 JAN 85 Model/Converter Identification - 700R4 325. ATRATB8524 JAN 85 No Converter Clutch Apply When Unit Is Hot 326. ATRATB8523 JAN 85 No Drive/Reverse/Third Gear Or Fourth Gear 327. ATRATB8517 JAN 85 No Upshift, Good Reverse and Drive - 700R4 328. ATRATB8529 JAN 85 No-Reverse, Shudder, Or Delayed Reverse - 700R4 329. ATRATB8520 JAN 85 Occasional No-Reverse, Or Shudder In Reverse 330. ATRASIL853 JAN 85 Pump Assembly - Part Numbers 331. ATRATB8513 JAN 85 Pump Cover Screen - 700R4 332. ATRATB8543 JAN 85 Recurrent Sticking Valves - Automatic Transmission 333. ATRATB8521 JAN 85 Sleeving Governor Bore - 700R4 334. ATRASIL8526 JAN 85 Solenoid Reference Chart - 700R4 335. ATRASIL8524 JAN 85 Updated Input Shaft/Pump/Converter - 700R4 336. ATRASIL8535 JAN 85 Updated Oil Pump - 700R4 337. ATRASIL8531 JAN 85 Updated Pinion Carrier - 700R4 338. ATRATB8545 JAN 85 Valve Chatter/Not Enough Oil Feed - 700R4 339. 8526 JAN 85 Wire Wheel Cover - Noisy At Low Speeds - Repair 340. 8517 DEC 84 Add/On (Auxiliary) Electrical Equipment Installations 341. 84222 DEC 84 Power Window Regulator Assembly Special Policy Adjustment Bulle 342. 84226 DEC 84 Radio Ignition Noise 343. 84225 DEC 84 Replacement Brake Pad Usage 344. 84223 DEC 84 Ride Harshness Z-51 Suspension 345. 8512 NOV 84 Fuel Line "O" Rings 346. 841676 OCT 84 "Add On" of Electrical or Vacuum Operated Equipment 347. 8483 OCT 84 A/C Compressor Shaft Seal Usage 348. 855 OCT 84 Burned 3-4 Clutch and/or High 2-3 Shifts 349. 84198 OCT 84 Engine Overheating 350. 84208 OCT 84 Low Speed - "Chuggle" 351. 84200 OCT 84 Stabilizer Bar Link Attaching Nut 352. 84213 OCT 84 Transmission Maintenance Information - Four-Speed Manual Transm 353. 84191 SEP 84 Automatic Transmission Identification Information 354. 84180 AUG 84 Engine Oil Level Operating Range 355. 84179 AUG 84 Harsh 1-2 Upshift 356. 84177 JUL 84 Burned Overrun Clutch, Forward Clutch, and 3-4 Clutch Plate Ass 357. 84159 JUL 84 Cleaning and Lubricating Power Antenna Mast Sections 358. 84176 JUL 84 Rear Tie Rods 359. 841607AVII JUL 84 Revised Flywheel Bolt Torque 360. 84162 JUL 84 Slips In Reverse (Burned LO and Reverse Clutch Plates) 361. 84161 JUL 84 Trouble Shooting Hints On 1984 Custom Cruise III (K34) 362. 84141 JUN 84 Brake Squeal 363. 84150 JUN 84 Dead Battery or No Crank After Overnight Set 364. 84144 JUN 84 Elimination of 4-3 Downshift Switch to Reduce Possible 4-3 Down 365. 84149VICLONE JUN 84 Loss of Engine Oil Pressure After Oil Change - Gas Engine 366. 8467 JUN 84 Outside Rear View Mirror "Loss of Adjustment" 367. 84626AVI JUN 84 Rocker Cover Oil Leaks On Small Block V8 or 90~ V6 Engines 368. 84148 JUN 84 Transmission Oil Exhausting Out the Vent Pipe 369. 84127 MAY 84 Cleaning, Painting, and Coating of Aluminum Wheels 370. 84121 MAY 84 Dealer Installed Anchor For Child Seat With Top Strap Anchor In 371. 84130 MAY 84 Engine Oil Cooler Leaks 372. 84113 APR 84 Brake System Service Information 373. 84102 APR 84 Chattering Windshield Wiper Blades and/or Uneven Wipe 374. 84103 APR 84 Checking Pinion Washer For Possible Wear 375. 84117 APR 84 New Input Housing and Shaft Assembly 376. 84112 APR 84 Roof Panel Attaching Plate Repair 377. 84108 APR 84 Service Procedure For the Oil Pump Rotor and Slide 378. 84118 APR 84 Side Door Lateral Movement 379. 8485 MAR 84 Anti-Chip Coatings 380. 8489 MAR 84 Engine Oil Recommendations 381. 8486 MAR 84 Grinding Noise In All Ranges or No Drive Condition On THM 700-R 382. 8461 MAR 84 Transmission Oil Exhausting Out the Breather On Vehicles With 7 383. 8464 FEB 84 1984 Corvettes Painted With 1986 Colors For General Managers CO 384. 8460 FEB 84 Half-Shaft and Propshaft Clinking Noise 385. 83I115 FEB 84 New 2-4 Servo Cover and Seal 386. 8469 FEB 84 Oil Pan Leaks On THM 700-R4 Transmissions 387. 8468 FEB 84 Partial Forward Clutch and/or Band Apply In Reverse Gear On THM 388. 83122 FEB 84 RTV Sealer and Gasket Eliminator 389. 8474
18
guests, and
11
spiders. |
Admin,
Global Mod,
