Topics3,619
Posts6,719
Most Online265 Jan 21st, 2023
#759 - 02/07/06 11:04 AM
Power enrichment and other fuel related questions
Here a couple of things I’d like to understand: During PE (and assuming COT is disabled) the PCM will inject a certain amount of fuel ON TOP of what it would need if it was in closed loop. Example: 1.2 PE means 20% more fuel than stoichiometric = 14.7/1.2 = 12.25 This should be the AFR I see on my wideband. Correct? IFR: I have installed a new set of flow matched Bosch injectors. They are built same as the stockers: they are rated at the same pressure and just flow a little more. I also installed an additional fuel pump in line with original one. Old injectors: 28.4 lbs/h New injectors: 36 lbs/h Old pressure: 55 PSI New pressure: 64 PSI The factor to calculate the new IFR is SQR(64/55)x36/28.4 = 1.3674 So I should multiply the old IFR values by this factor. Correct? VE: I drove around for a while in SD (MAF fail freq = 0, low octane table = high octane table). Result: all cells between 0 and 15 were +/-2% LTFT. Can I assume that the stock VE table is correct? In this case I think the new IFR table is fine. Don’t look at my signature: right now the engine is NA; it only has a K&N FIPK filter and has stock internals. That’s why I assume the stock VE is correct. MAF table: after putting back the program to work with the MAF I logged Raw Frequency and LTFT. This allows me to make a pivot table in Excel and I can see for what frequency I need to change the G/sec value of the MAF table. The result is fine, the method works: in closed loop all LTFT are pretty close to zero. I had to change the stock MAF curve just a little (2-3%) and smooth it down so that it still looks like a curve. Now the problem: In PE and commanding an AFR of 12.8:1 (see above how) I can measure values in the region of 13.5! 12.8 is about 14.8% more fuel, but 13.5 are only 8.9%! Where is the mistake? Is the stock VE table wrong and makes me believe the IFR table is correct? Should I change the MAF curve in the high frequency range? This of the commanded AFR is a BS? Should I just add/reduce fuel until is fine and don’t bother about the theoretical numbers? OK, this was a long post, but how tell those things in a simpler way? Thanks - Stefano
#760 - 02/08/06 12:54 AM
Re: Power enrichment and other fuel related questions
Your post is quite confusing since you state the engine is stock but are tuning MAF and VE tables, why I do not know.
There is zero reason with stock engine to be doing so.
I'd suggest go back to stock setting for those functions. Set IFR to vales that would be close which is about 25% higher values then stock values are and set PE/RPM values across the table at 1.145
Do the flashing. clear any error codes, do idle relearn, drive about 30 miles for PCM to relearn and then do a testrun with a scanner recording. From that data tweak the IFR to get LTFTs +/- 5% and only then tweak PE/RPM values.
From what I see in your post is your jumping all over the place and making one area better but then hosing that with changes that are not needed for the PCM will readjust and once LTFTs are close PCM will adjust properly and tune will be fine. I suspect what you read on other forums has you chasing your tail.
MAF sensors measure airMASS, even if so called porting is done that does NOT change the sensors measuring ablity one bit.
VE as I have shown are for startup and decel under 4,000 RPMs and as a backup if MAF was to fail, THAT IS IT, so screwing with those tables only forces PCM to calculate functions like torque, engine load, airmass, etc incorrectly and thus adjust incorrectly.
#761 - 02/08/06 02:36 AM
Thank you for the answer, Actually I haven't changed the VE table: I made a run in SD only to see if the IFR table was correct. Maybe not the best idea The MAF is also stock and I was thinking it was an option to tune fuel by changing the MAF table (like before with the MAF-translator...) But I understand what you say, It's probably so that I'm making too many changes in places that I shouldn't touch Another question: is the IFR table supposed to be a straight line? Or can it be curved so to have more/less fues at certain MAP values? Thank you - Stefano
#763 - 02/09/06 03:30 AM
Is it a good idea to log for MAP and LTFT and change the IFR table accordingly? This only for cells 0-19. I see LTFT values around 0% for cells #10 and 15 and about -8% at idle and cells like #0 and 1, that's why I was thinkin the IFR table could be something different than a straight line. The other possibility is to change the MAF curve logging for raw frequency and LTFT. I know both systems work(IFR and MAF), I just should choose a strategy and not change both as you wrote before: From what I see in your post is your jumping all over the place and making one area better but then hosing that with changes that are not needed for the PCM
#764 - 03/02/06 11:50 AM
OK, I left the MAF and VE table stock and played only with the IFR (logged LTFT's vs. MAP).
The IFR table is now a curve with a little higher values at low MAP. The LTFT average is around zero +/- 2%). The car itself drives as usual but the LTFT are more consistent. Tuning the MAF curve they changed depending on the driving time and on the wheater. Now they remain pretty constant.
The STFT's used to bounce up and down a lot (+/- 7-8%). Now they are about +/- 3%.
The big surprise is the fuel consumption: On the highway at constant speed it used to be much better than on country roads. Now it's about the same. I mean: on countrie roads it needs as "low" as on the highway! This in winter and during short trips.
#766 - 03/02/06 04:22 PM
Originally posted by teamzr1: Its hard to look at gas mileage on cold winter weather but I'd suspect the MPG will increase a bit in summer for keep in mind winter gas makeup does not give good MPG What is the difference in the USA? Over here I think it's the same Originally posted by teamzr1: You might try a test of setting IFR a bit leaner across the board, as long as you do not have ping then engine will perform better and MPG will also increase Does it mean that with positive LTFT's the engine is running light lean to stoichoimetric? And with negetive LTFT's it's light rich to stoichoiometric? Originally posted by teamzr1: Being you have water injection I would not expect a linear IFR table since when WI is on makes AFR about 8% richer thus IFR needs to be commanded with shorter injector pulse width when WI is on WI turns on at 2 PSI and off at 0.5 PSI. For my particular (low boost) setup this additional enrichment happens in open loop only. I was able to tune the IFR only in the closed loop range (20 - 90 kPa), over 90 kPa I just set it as a linear continuation of the curve. I now have to check what happens in PE... How does the PCM calculate the IFR under boost? My MAP only sees 105 kPa max, the IFR goes only up to 100 kPa. Does it keep the last value @ 100 kPa? Does it extrapolate up to 105 kPa then it's linear? I ask because there's something I don't understand: After 105 kPa I think the PCM keeps a constant value. In reality there's less fuel flowing because of the backpressure in the intake manifold. But the PCM doesn’t notice that. At the same time the MAF is checking for the amount of air and commands the injectors accordingly. With constant PE vs. RPM values I should see the AFR rising proportional to the RPM (and to the boost). In reality the AFR remains constant (that was with water alone. So the AFR wasn’t affected by the alcohol). Why? Something similar happens when the supercharger is disconnected: with constant PE vs. RPM values the AFR at WOT decreases at high RPM. Linearly. Can I assume that my MAF is seeing more air than what really flows? In NA and at WOT I see a constant MAP of about 90 kPa, so this is not something I can adjust with the IFR. Is there some other factor that influences the AFR at WOT? COT is disabled and the temperature is 190 – 200F. What else could it be? Stefano
#768 - 03/03/06 02:52 AM
This is what happens at WOT (non supercharged): the blue line is the commanded AFR (1.145), the red line is the result (smoothed). Why is it a curve? I was expecting a parallel to the commanded AFR, but not a curve. ![[Linked Image]](http://memimage.cardomain.net/member_images/4/web/460000-460999/460473_216_full.jpg)
#770 - 03/07/06 06:16 AM
As said right now the blower is disconnected and I only have a FIPK filter (similar to the blackwing filter for the corvette). VE table is stock, Timing table is stock (28* at WOT), MAF table is stock. Only the IFR table has been changed, but at WOT I saw a constant MAP so the PCM is always using the same IFR value.
That the measured AFR is lower than the "commanded" is not so strange (IFR is maybe still not right), I just don't understand why it makes a slope. Like if the MAF was seeing more air than what it was.
Unless there are other factors that influences fueling that I don't see in Edit. There is a PE vs coolant temperature, but at 200F the correction is zero. The measured timing was also 28* without KR.
I know: the AFR is not too much out and I could correct it in the PE vs RPM table and call it a day. I just was wondering why it's a curve and not a line...
Thanks - Stefano
#771 - 03/31/06 03:13 AM
Short report It's a while now that I changed the IFR table and the tune is still OK. LTFT change a little depending on wheater conditions (go a little positive when cold) but that's OK. What I did was log for LTFT, fuel trim cell and MAP. LTFT are averaged, MAP is rounded to the next MAP value in the IFT table. I used only cells 0-19. I then put LTFT ans MAP in a pivot table (Excel). The result is a correction in % of the specific IFR value. So far so good! I used to tweak the MAF table but never with good results. At least not as good as only changing the IFT table. A side effect of changing the MAF table is a wrong G/cyl value which affect timing also!!! I used to reduce the MAF values to adjust fueling: less G/sec means less G/cyl and in general higher timing than necessary (PING!) Here the actual IFR curve: an untypical shape, but LTFT are now +/- 2% with an average of almost zero Stefano ![[Linked Image]](http://memimage.cardomain.net/member_images/4/web/460000-460999/460473_224_full.jpg)
#773 - 03/31/06 05:04 PM
You cannot blindly use cells 0 to 19 as a bulk value since some cells are used for decel and fuel learn is off thus your trim average is bloated since its adding into the trim average when PCM is commanding fuel off thus would be leaner on decel but being added to when fuel is commanded on I was thinking only in cell 21 the PCM will turn off fuel learn (in fact I see an AFR of around 13 on the WB but the LTFT remain constant at about -2%). During fuel cut off it's another story. I also see cell 0,1, 4 and 8 in decel (mostly 0 and 1) but the AFR is stoichiometric (so I assume the PCM is learning). What cells would you consider? I tried 0-19 and 0-15 and the result is exactly the same. For MAP over 85 - 90 kPa it's quite difficult because it goes in PE, so I just continued the line by feeling (values 90 - 100 kpa). Is there another way to determinate this last piece of the IFR curve? Stefano
#775 - 04/02/06 05:09 PM
OK, I managed to separate the decel values in Excel. It's true: it doesn't follow the cell numbers. Mostly cell are 21, 0, 1 and 4. But not only. Result: the same IFR line as I posted before. I'm happy with the result, I just don't understand the shape of the curve at low MAP. It just doesn't make sense (to me). Do you have an explaination?
Stefano
#777 - 04/03/06 01:50 AM
I just wanted to say that this IFR curve is a little strange in the low MAP range. As you said Excel would average everything (also during decel)so I changed the spreadsheet to consider only the scan data related to acceleration and not decel. Considering acceleration only doesn't change the IFR curve, so I guess this is what my engine wants. (This curve is the result of a 2 hours scan, using only cells 0-19, cell 15 only when not in PE). I was just surprised to see lower G/sec at 30 kPa than at 20 kPa. Stefano ![[Linked Image]](http://memimage.cardomain.net/member_images/4/web/460000-460999/460473_224_full.jpg)
#779 - 04/03/06 06:11 PM
Stock engine at idle around sealevel is around 30-35 KPA Map. Compare 10-30 KPA when fuel learn is ON and you also see less then 30 KPA, torque less then 30 lbs to negative where 30 plus KPA engine is pulling more engine load and timing to maintain idle We are at about 500 m here (1640 ft), at hot idle I see about 30 kPa. With AutoTap I can't see if the fuel learn is on, or at least I don't know how (do you know if Autotap can do that?) Your values almost look like your scanner is backwards and not KPA but in inhg
I adjusted the values to fit the LS1Edit IFR table. It's easier to compare / change the values. According to the scanner the pressure is in kPa (??) and not in inHg
#781 - 04/04/06 04:01 AM
Ease Enhanced OBD-II Powertrain Scanner ? Are there other producs you would suggest?
I see what you mean by "you need to know what PCM has either commanded injectors off or went to min pulse width". Right now I see LTFT / STFT values that don't make too much sense. After a while I'm at idle the fuel trims go negative without an apparent reason (?) I have #36 injectors and at minimum pulse width they could still put too much fuel in the engine.
Also the averaged cells change depending on the wheater. It was 0% at 60F and +2/+3% at 40F. I wonder if this is the result of a wrong tune or of wrong data from the scanner (???)
What a mess!
#782 - 04/04/06 08:47 AM
I suggest the Ease scanner because they are a tier 2 suppler to GM so their scanner was designed with GM engineering input and information that is not known by the public for their enhanced PIDs plus how the VPW functions. If interested you can purchase it via our frontstore and this is the model you would want : Ease GM Enhanced OBD-II Your autotap does less then about 10 frames a second where with Ease you get 40 F/ps. In your case PCM cycles are then missed where with the Ease your getting far more data cycles. Also the Ease supports all GM PIDs, has bi-directional, full EPA IM snog tests and O2 tests.
#783 - 04/05/06 09:57 AM
OK, let me think about that.
Here another question: is there a natural reason of having different LTFT's depending on the wheater? Temperature? Air umidity? Pressure? Or can it be related to a tuning problem?
The difference between 30F or 70F is 4 - 5% Is that normal? Should I just take something in between?
#784 - 04/05/06 11:27 AM
Sure weather will have a effect. Try using the weather calculator on my website, direct is Weather cost to performance Make weather changes with it and see the effect it has. Hot air adds to the correction factor of HP/Tq which is a loss of performance where colder airmass would increase performance so it clearly has effect to AFR and fuel trim values You see a hugh effect to weather to AIR effect on performance. Clearly you know in summer heat engine does not perform as well as nice fall or spring weather so air quality effects AFR and reason why using the MAF is much better adjusting tool for the PCM then those people deleting the MAF and use VE speed density as to how PCM determines how much fuel to add to qualty of airmass. As to tune corrections I slant on the lean side as long as there is no knock pulling timing so there is no rule that LTFTs must be a perfect zero being as long as STFTs are +/- 5% PCM ignores LTFTs and does no correction to them
#785 - 04/05/06 03:04 PM
Interesting calculation! As I expected Dewpoint has a big influence... This is the only real problem of a MAF: it measures mass. Air mass but also humidity mass. So with umid air the MAF will "see" more air than what it really is, causing more fuel to be injected. At this point the O2's will notice the difference and cause negative fuel trims. Right? In my company we have a couple of gas flometers: they are similar to a MAF in their function. There's no chances to have a correct reading if we don't have a drier installed before them! So what to do? Install a big drier in front of the car?
#787 - 04/07/06 03:10 AM
Is it better to consider LTFT and STFT together?
correction = (LTFT B1 + LTFT B2)/2 + (STFT B1 + STFT B2)/2
This assuming that x% correction for STFT has the same weight for LTFT also.
Example: +4% LTFT and -7% STFT means a total adjustment of -3% (for a particular FTC)
#788 - 04/19/06 08:23 AM
This assuming that x% correction for STFT has the same weight for LTFT also OK, I'll answer myself: see here the result of 2 very long scans (3 hours each, visiting my parents for Easter). Notice the IFR curves calculated from the LTFT's: they are different. The other 2 IFR curves are the result of considering LTFT's + STFT's and are the same! This means (to me) that the formula above (averaged sum of LT and ST) is correct. As stated by JR LTFT will change only if STFT are higher/lower than +5/-5%. Considering LTFT alone can lead to wrong values (as I personally experienced!). The 20-30 kPa area is pretty strange I also wonder if and how much the EGR influences the whole story Stefano ![[Linked Image]](http://memimage.cardomain.net/member_images/4/web/460000-460999/460473_225_full.jpg)
#790 - 04/20/06 01:00 AM
Oh, I wasn't looking for performance but I wantend to understand how this part of the PCM works. Since I loaded the new IFR curve (considering LT and ST) and resetted the PCM most LTFT are = 0 and only few are +/- 2%. STFT are most of the time +/- 3/5%. This for different driving conditions (accel/decel) and outside temperatures (40/70F). When I only considered LTFT, driving style and temperatures had a bigger influence. But it's clear: as long it runs in closed loop it doesn't make a difference: the O2's will manage that
21
guests, and
15
spiders. |
Admin,
Global Mod,
