Bulletins for 1990 Chevrolet Corvette V8-350 5.7L
                                          Safety Recalls
     TSB Number   Issue Date  TSB Title
  1. 90C09A5        MAR 90       Product Campaign 90C09(A) Inoperative Parking Brake
                                          General Recalls
  1. 90C095         JAN 90       Campaign 90C09, Inoperative Parking Brake
  2. 90C078C        JAN 90       Instrument Wires Rubbing On Bracket, Campaign 90C07
                                         Service Bulletins
  1. 99-00-89-022   DEC 99       The Year 2000 and Vehicle Electronics
  2. 99-00-84-021   NOV 99       Expediting Parts
  3. 99-06-04-053   NOV 99       Powertrain Control Module Reprogramming
  4. 99-08-42-009   NOV 99       Setting of I/P Dimmer Control to View PRNDL Display
  5. 99-06-02-017   OCT 99       Radiator Repair/Replacement Guidelines
  6. 99-08-51-007   OCT 99       Refinishing Aluminum Wheel
  7. 99-00-89-019   OCT 99       Warranty Parts Center/Corporate Parts Return Program
  8. 99-00-01-001   SEP 99       AC Delco Remanufactured Engines
  9. 99-07-30-017   SEP 99       Auto/Trans Oil Cooler Flushing and Flow Check Procedures
 10. 99-07-30-020   SEP 99       Automatic Transmission Service Procedure Change
 11. 99-08-64-016   SEP 99       Use of Silicone for Weatherstrip Maintenance
 12. 000000A        JUL 99       GM Service Bulletin Precautions
 13. 99-03-10-102   JUN 99       Original Equipment Chrome Plated Aluminum Wheel ID
 14. 99-08-49-006   APR 99       Cleaning of  Upper Instrument Panel Surfaces
 15. 99-08-51-001   APR 99       Paint-less Dent Repair Process
 16. 99-06-03-002   MAR 99       Battery Insulator Replacement
 17. 99-06-03-001   MAR 99       Essential Tool J 42000 Battery Tester
 18. 83-81-34       MAR 99       Operating Vehicle with SIR Warning Light On
 19. 99-00-89-002   MAR 99       Using the New GM Service Bulletins
 20. 86-05-02       DEC 98       Delayed Warranty Start Process
 21. 87-71-74       NOV 98       1-2 Accumulator Piston and Outer Spring Replacement
 22. 83-35-08       NOV 98       Chemical Staining of Chrome Wheels
 23. 72-05-08B      NOV 98       Repair/Exchange Procedures and Options
 24. 83-32-10       NOV 98       Tool J 43435 Adjuster Locknut Wrench
 25. 83-32-09       NOV 98       Tool J 43485 Power Steering Bleeder Adapter
 26. 83-15-16       OCT 98       New Windshield and Glass Urethane Adhesive Caulking Kit
 27. 76-02-02A      OCT 98       Recommended  Axle  Lubricant
 28. 84-96-01       AUG 98       Correct Labor Code Usage for Entertainment Systems
 29. 83-90-12       AUG 98       Keyless Entry Transmitter Tester
 30. 80-05-03       AUG 98       Redefined Use of Parts Warranty Special Claims B and C
 31. 83-96-05       JUL 98       Radio Telephone/Mobile Radio Inst/Troubleshooting
 32. 83-90-08       JUN 98       Charts and Schematics for Cruise Control Diagnosis
 33. 77-72-04       JUN 98       ZF 6-Speed Manual Transmission Service Procedure
 34. 82-05-03       MAY 98       Elimination of Labor Op Z7920/Z7930
 35. 82-05-05       MAY 98       General Motors Warranty Inquiry System
 36. 82-05-02       MAY 98       Request for Authorization Using Routing Code  H
 37. 83-05-02       APR 98       Labor  Time  Guide Updates
 38. 87-61-24       APR 98       Use of Surface Conditioning Discs
 39. 48-05-01C      MAR 98       Customer Concern Not Duplicated /Verified - Labor
 40. 83-05-01       MAR 98       Labor  Time  Guide  Updates
 41. 83-64-09       MAR 98       Tool J 41450-B Released for CS Generator Diagnosis
 42. 83-01-14       MAR 98       VIN Plate Replacement
 43. 72-05-09       FEB 98       GM Dealer Empowerment Program
 44. 73-05-09       FEB 98       Labor Guide Updates
 45. 82-05-01       FEB 98       New Vehicle / Replacement Battery Warranty Instructions
 46. 73-50-37       JAN 98       Brake Rotor and Hub Cleaning Tool Revision
 47. 72-05-14       JAN 98       Enhanced Sublet Repair Policy
 48. 73-90-23       JAN 98       Frontal (SIR) ON-Off Switch Kits, Parts and Procedures
 49. 73-05-09       JAN 98       Labor Times Update
 50. 72-05-13       JAN 98       Repair/Replace Policies and Procedures
 51. 72-05-12       JAN 98       Shock Absorbers and Struts Operations
 52. 72-05-07       DEC 97       ACDelco Remanufactured Engines
 53. 73-05-07       DEC 97       Labor  Time Guide Updates
 54. 72-05-11       DEC 97       Rail Dust Removal and Chemical Spotting - labor
 55. 71-05-02       DEC 97       Recall Campaign Follow-Up Post Card
 56. 73-01-10       DEC 97       Technical Assistance Call Preparation
 57. 48-05-01A      NOV 97       Customer Concern Not Verified/Duplicated Labor Operation
 58. 62-05-02A      NOV 97       Labor Operation Z1241 - Personal Property Damage
 59. 73-05-07       NOV 97       Labor Time Guide  Updates
 60. 73-12-13       NOV 97       PureGuard 2 Operating Alert
 61. 72-05-08       NOV 97       Repair Categories/Options and New Shipping Procedures
 62. 73-05-06       OCT 97       Labor Time Guide Addition
 63. 73-05-06       SEP 97       Labor Time Guide addition
 64. 73-62-13A      SEP 97       Servicing of Aluminum Heater Cores and/or Radiators
 65. 72-05-04       AUG 97       Guidelines for Claiming C0034 - Windshield Replacement
 66. 72-05-06       AUG 97       Guidelines for I/M 240 Labor, J9980-I/M, J9981 and J9982
 67. 72-05-05       AUG 97       Guidelines for Using E0420 Wheel Replace
 68. 72-05-03       AUG 97       Guidelines for Wheel Alignments and Wheel Balance
 69. 73-05-05       AUG 97       Labor Times
 70. 73-62-13       JUL 97       Aluminum Heater Core and/or Radiator Replacements
 71. 73-62-14       JUL 97       Approved Engine Coolant Recycling Processes
 72. 73-05-04       JUN 97       Labor Time Update
 73. 73-10-54       MAY 97       Two-Part Urethane Adhesive For Windshield Installations
 74. 631208A        APR 97       A/C Tool And Equipment Maintenance
 75. 73-05-03       APR 97       Labor  Time  Guide  Update
 76. 730503         APR 97       Labor Times Guide Update
 77. 620504         APR 97       Operating Procedures
 78. 731204         FEB 97       Air Conditioning Systems With R12 Or R134a Service Issue
 79. 731049         FEB 97       Body Sealer Tape For Collision Repairs
 80. 730501         FEB 97       Update Labor Time Guide
 81. 730502         FEB 97       Updates Labor Time Guide
 82. 630507         JAN 97       Updates Labor Time Guides
 83. 649601         JAN 97       Compact Disk Players Procedures
 84. 436407A        JAN 97       Low  Voltage Reading Or Dim Lights At Idle
 85. 600503         JAN 97       Warranty Repairs And Claims Procedures
 86. 62-05-03       DEC 96       Dealer Prohibited Use of Labor Open. and/or Claim Type
 87. 63-05-06       DEC 96       Updates to Labor Time Guide
 88. 310503C        DEC 96       Warranty Claim Processing
 89. 610111         NOV 96       Key Code Information
 90. 630504         OCT 96       Warranty Administration Labor Time Guide Updates
 91. 630505         OCT 96       Warranty Labor Time Guide Updates
 92. 668304A        SEP 96       ACDelco Service Center Locations Odometer/Speedometer
 93. 400501A        SEP 96       Corporate Parts Return Program Instructions
 94. 630503         SEP 96       Labor Time Guide (Request for Review) Updates
 95. 636532         MAY 96       Enhanced Emission Inspection Maintenance - Equipment
 96. 631209         MAY 96       R12 or R134a A/C Vehicle Service Issues
 97. 676117A        MAY 96       RTV Sealant - Use of Wacker T-330 for Intake Manifold
 98. 638111         APR 96       Headlamp Lens Distortion Caused by Aiming Equipment
 99. 636401         FEB 96       Updated Battery Replacement Catalog Numbers
100. ATRATB334      JAN 96       Delayed Forward Engagement / Burnt 3-4 Clutches
101. ATRATB256A     JAN 96       Rear Planet Failure - Lack Of Lube
102. 516547         JAN 96       Revised Tech 1 Cartridge for Oxygen Sensor Test
103. 536507         DEC 95       Enhanced Emission Inspection Maintenance - Update
104. 531021         NOV 95       Waterleak Diagnostic Guide
105. 538209         OCT 95       Daytime Running Lamp Retrofit Kits
106. 580504         AUG 95       Inspection/Maintenance Labor Operations
107. 588302A        JUL 95       AC Delco Locator Service for Delco Electronics Exchange
108. 570102         JUN 95       Reformulated, Oxygenated Gasoline and Calif. Phase 2 RFG
109. 580101         JUN 95       Use of a Diagnostic Worksheet
110. 531205         MAY 95       Contaminated R12 Refrigerant Testing & Handling
111. 510103         MAY 95       GM Campaign Identification Label
112. 520506         APR 95       ADCSM Empowerment Parameters Retail Matrix
113. 570501         APR 95       Goodwill Adjustments Case-by-Case Administration
114. 520505         APR 95       Panel Replacement Operations for Corrosion Repairs
115. 436201B        APR 95       Propylene Glycol Engine Coolant
116. 570201         MAR 95       General Information - Dexron® III A/T Fluid Introduction
117. 431218A        MAR 95       J 39400 A/C Leak Detector Maintenance Kit Availability
118. 420515A        FEB 95       Chevrolet Claim Processing
119. 516502         FEB 95       I/M Emissions Diagnostic Manual
120. ATRATB294      JAN 95       Axle Nut/ Lug Nut Tightening Specifications
121. 436510         JAN 95       I/M 240 Program - Equipment Purchase
122. ATRATB292      JAN 95       No 2nd, No 4th and No TCC - 700-R4
123. 436507         DEC 94       Enhanced Emission Inspection Maintenance Program
124. 435009         DEC 94       Front Brake Pulsation - New Diagnosis and Repair
125. 431048         NOV 94       Adhesive Caulking Kit Revisions
126. 431606         OCT 94       Cleaning Procedure for Leather Seat Covers
127. 436506         OCT 94       I/M 240 Repairs - Obtaining Technical Assistance
128. 446501         OCT 94       PROM/MEMCAL - Identification Marks
129. 431223         SEP 94       Contaminated A/C Refrigerant
130. 410103         SEP 94       Product Campaign Bulletin Numbering System
131. 330105A        SEP 94       Using GM Service Bulletins
132. 449001         AUG 94       Diagnosing SIR DTC 24
133. 149301         JUL 94       Release of Service Package For Nickel Tape
134. 433502         JUL 94       Speed Rated Tires
135. 431501         JUN 94       Scuffed Paint On Convertible Top Storage Compartment Lid
136. 431018A        MAY 94       Vehicles Equipped With A Webasto Sunroof System
137. 436505         APR 94       Enhanced Emission Inspection Maintenance Programs
138. 033206         MAR 94       Reduced Power Steering Assist (Cold)
139. 435001         FEB 94       Aftermarket Anti-Lock Brake System Products
140. 476503         FEB 94       Hard Starting - Updated PROM
141. 330106A        FEB 94       New DCS Bulletin Search and Access to Vehicle Options
142. 310504         FEB 94       Policy - Recycled Engine Coolant
143. ATRATB234      JAN 94       Forward Sprag Design - 700-R4
144. ATRATB257      JAN 94       Missing Reverse Checkball - 700R4
145. ATRATB265      JAN 94       Rear Planet Failure (Lack of Lube)  700-R4
146. 331226         JAN 94       Retrofitting R-12 Vehicles to R-134A
147. 936003         DEC 93       Conclusion of the Engine Exchange Program
148. ATRATB201      DEC 93       No Line Pressure Rise - Stuck Pump Slide
149. ATRATB196      DEC 93       Shifts In Manual Low - 700-R4
150. 383001         DEC 93       Steering System Bleed Procedures
151. 331708         NOV 93       Clearcoat Degradation - Chalking and Whitening
152. 339008         NOV 93       Reduced FM Radio Reception
153. 306502         OCT 93       How Fuel Economy Is Determined
154. ATRATB179      JUL 93       Late Or No Upshifts
155. 393504         JUL 93       Leaking Cast Aluminum Wheels
156. ATRATB175      JUL 93       No 2nd Gear
157. 349212R        JUL 93       Radio Frequency Interference - Identification/Diagnosis
158. 316501R        JUN 93       Introduction Of The Fuel Injector Tester Tool
159. 931638A        MAY 93       Isolation Diodes Information
160. 931896E        MAY 93       Revised Fuel System Chart A-7
161. 931693E        APR 93       Tires Slipping On Rim
162. 9313310        MAR 93       Door Locks Binding or Sticking/Key Hard to Insert
163. 931437A        MAR 93       Manual Update Transmission Unit Repair 3 - 4 Clutch
164. 9313110        MAR 93       Rear Lift Window Hard to Open/Hinge Loose to Glass
165. 9358A10        FEB 93       Acid Rain and Rail Dust Damage to Base/Clear Coat
166. 93966C         FEB 93       Factors That Affect Fuel Economy
167. 939710         FEB 93       Paint Peeling From Muffler
168. 93774B         JAN 93       Differential Pinion Shaft Lock Screw
169. 91520A8A       JAN 93       Revised Chart 6 Electrical Troubleshooting
170. 93689A         DEC 92       Aftermarket Radio May Set DTC`S 72 and 74 In CCM
171. ATRATB134      NOV 92       Bind In Reverse - 700R4
172. 93297A         OCT 92       Buzzing Noise At Idle Coming  From the 4L60E A/T
173. 93316C         OCT 92       Effect of Fuel Volatility On Driveability
174. 93356D         OCT 92       Engine Miss, Hesitation or Roughness - Information
175. 923076         OCT 92       No Start Condition ( Starter Corrosion )
176. 93239J         OCT 92       Precaution On After-Market Alarm & Keyless Entry Systems
177. 923058A        OCT 92       Revised Fuel Gauge Charts
178. 9230810        OCT 92       Roof Panel Attaching Bolt Rattles
179. 93203E         OCT 92       Scuff/Scratch Removal From Aluminum Wheels
180. 93111D         SEP 92       Shaft Nut Removal HR6HE
181. 922501A        AUG 92       Use of Alternate Refrigerants In CFC 12
182. 922323E        JUN 92       Damage Due to Improper Mounting of Steel Wheels
183. 922306         JUN 92       Engine Noise W/ Clutch Engaged
184. 922286         JUN 92       Engine Service Program - LT5 ZR1 Engine
185. 91229A9A       JUN 92       Radio May Lose Some Functions
186. ATRATB118      JUN 92       Valve Body Interchange - 700R4
187. 914937A        MAR 92       No Reverse/Delayed Reverse Cold
188. 91451A8C       MAR 92       Oil Pressure Gage Flutters, or May Read High
189. 9211610        FEB 92       Convertible Stoward Lid Contacts Rack When Opened
190. 921078A        FEB 92       Cruise Control Intermittent Drop-Out or Fail
191. 92851D         FEB 92       Missing Block Fitting Sealing Washers From Service A/C
192. 923310         NOV 91       Acid Rain Damage to Base Coat/Clear Coat
193. ATRATB078      NOV 91       How To Use A Pressure Gauge - Automatic Trans.
194. 92351D         NOV 91       New Air Conditioning Compressor Sealing Washer
195. 92427A         NOV 91       Sporadic Transmission Slip, Downshift, or Busy Cycling TCC
196. 914496A        NOV 91       Tailpipe Smoke Blue or Bluish White On Startup
197. 913880A        AUG 91       A/C Delco Advance Exchange Programs
198. 913846E        AUG 91       Damaged and/or Misdiagnosed ECM/PCM
199. 913967A        AUG 91       Evaluating Peened Spacer Plates On All A/T
200. 913907A        AUG 91       New Output Shafts and Seal
201. 177114         JUL 91       3-2 Coastdown Clunk - 4L60
202. 913727A        JUL 91       3-2 Coastdown Clunk Noise On 4L60 A/T
203. 913717A        JUL 91       4L60/700-R4 Transmissions Stuck In First
204. ATRATB058      JUL 91       Valve Body Assembly 700-R4  Inspection
205. 913500B        JUN 91       Federal Vehicle Theft Prevention Standard
206. 913439A        JUN 91       Intermittent Radio Operations
207. 913446E        JUN 91       State Emissions Testing Information
208. 913426E        JUN 91       Typical Voltages and ECM Connector End View Charts
209. 913126E        MAY 91       Damage Multec Port Fuel Injectors Result
210. 913376D        MAY 91       Electrical Conditions Intermittent
211. 913276E        MAY 91       Enhanced EGR Diagnostics Code 32
212. 9133410        MAY 91       Hvlp-High Volume Low Pressure Paint Application
213. 913186E        MAY 91       Incorrect Mem-Cal Installation May Damage ECM/PCM Circuit
214. 912980A        MAY 91       Labor Time Guide Request For Review Updates
215. 904239A        MAY 91       Power Antenna Not Retract
216. 913213B        MAY 91       Steering Wheel Removal Procedure
217. 904208E        MAY 91       Wiper Motor Starts In Hgih Speed Only
218. 912837A        APR 91       Automatic Transmission Binding In Reverse Condition
219. 912850A        APR 91       Cleaning of Upper Instrument Panel Surfaces
220. ATRATB046      APR 91       Diagnosing Converter Lock-Up Problems
221. 9128210        APR 91       Importance of Checking Clear Coat Thickness
222. 912841A        APR 91       Loose or Missing A/C Access Fitting Caps
223. 912316D        MAR 91       Intermittent No Start, Loss of Ground Path
224. 912415         MAR 91       ABS Self Test Initialization Cycle Noise
225. 9041210        MAR 91       Inoperative Power Seat and/or Blows Fuse
226. ATRATB043      MAR 91       No 4th, Late 4th, Falls Out Of 4th - 700-R4
227. 912356B        MAR 91       Use of Recycled Engine Coolant
228. 904108E        MAR 91       Wiper Motor Starting In the High Speed Only
229. 911867A        FEB 91       New Wave Plate Is Now Available 4L60 A/T
230. 912136D        FEB 91       Parasitic Current Drain Procedure, No Start Condition
231. 912043B        FEB 91       Proper Installation of the SIR Coil Assembly
232. 912083B        FEB 91       Reduced Power Steering Assist At Low Temperatures
233. 904006E        FEB 91       Revised Air Conditioning Circuit Diagnosis Chart C-10
234. 904019         FEB 91       Supplemental Inflatable Restraint/Revised Wiring Colors
235. 911713E        JAN 91       Tire Damage Caused In GM Assembly
236. ATRATB030      DEC 90       Bind-Up On The 1-2 or 3-2 Downshift
237. 911335         DEC 90       Change In Brake Feel After Rotor Refinishing
238. 903893E        DEC 90       Defective Tire Pressure Sensors
239. 911389A        DEC 90       New Setting Procedures For "Delco-LOC II"
240. 911127A        NOV 90       3-4 Clutch Plates (Steel) Are Available For 4L60
241. 911268E        NOV 90       Chattering Wiper Blades
242. 9037510        NOV 90       Door Lock System Replacement Components Information
243. 903778A        NOV 90       Electrical Diagnosis
244. 903781A        NOV 90       HVAC Control Loss
245. 903763B        NOV 90       Shudder/Groan From Steering
246. 903727A        OCT 90       4L60 Service Replacement Model Update
247. 903506E        OCT 90       Driveability and Emissions Revised Code 34 Chart
248. 903486E        OCT 90       ECM Terminal End View Chart Revised
249. ATRATB028      OCT 90       Engine Testing With A Vacuum Gauge - Auto Trans.
250. 91858A         OCT 90       Procedure For Checking Connector Terminal Contact
251. 903738C        OCT 90       Revised Odometer Recalibration Procedure
252. ATRATB024      SEP 90       Harsh Reverse Engagements
253. ATRATB010      SEP 90       Torque Converter Identification
254. 903273B        AUG 90       Clicking Noise In Steering Wheel
255. 9030610        AUG 90       Competition Yellow Paint Characteristics
256. 91626B         AUG 90       Coolant Specification
257. 91353E         AUG 90       New Coated Wheel Weights For Aluminum Wheels
258. 902935         JUL 90       Brake Lathe Produces Poor Brake Rotor Finish
259. 902973C        JUL 90       Front Suspension/Revised Torque Specifications
260. 902536D        JUL 90       Ignition System Revised Spark Plug Coding Chart
261. 902893D        JUL 90       Rear Suspension Revised Rear Spring Chart
262. 9029110        JUL 90       Seat Belt Buckle Extender Has Been Released
263. AM90125        MAY 90       White Overspray Sustained During Shipping
264. 902466A        MAY 90       New Design Cylinder Heads
265. 902488B        MAY 90       Underhood Lamps Are Inoperative or Stay On
266. 91108A         APR 90       Aftermarket Accessories Installation Guidelines
267. 91148A         APR 90       Checking For Parasitic Current Drain
268. 9020310        APR 90       Hardtop Mounting Bracket Rattle
269. 902237A        APR 90       New Clutch Support Dimensions
270. 902166         APR 90       Prevent Leakage of Small 75 mm Oil Filters
271. 902299         APR 90       Supplemental Inflatable Restraint/Revised Code 42 Chart
272. 91090A         APR 90       Used Anti-Freeze Policy
273. 91049          MAR 90       Inflatable Restraint Steering Wheel Removal/S.I.R. - Tools
274. 901897A        MAR 90       Material Change For Clutch Apply Plates
275. 901996E        MAR 90       Revised Chart C-1D, Code 33, 34, 63, 64
276. 9018310        MAR 90       Stowage Compartment and Rear Deck Height Difference
277. ATRATB9002006  FEB 90       Automatic Transmission Fluid
278. 901756D        FEB 90       Battery Chart General Specifications Update
279. 901627A        FEB 90       New Rear Bushing Removal/Installation Procedure
280. 9015410        FEB 90       Seat Cushion Retainer Wire Service Kit
281. 90980A         JAN 90       "Infl Rest" Indicator Lamp May Stay Lit
282. ATRATB9001003  JAN 90       Lubrication Correction - 700R4
283. 901116A        DEC 89       Engine Lightweight Piston Design
284. 901011A        DEC 89       Heating or Cooling Control Loss
285. 901040A        DEC 89       Return of SIR Inflator Modules
286. 901063E        DEC 89       Wheel Alignment Specifications
287. 909210         NOV 89       Carpet Inserts Become Loose
288. 90897A         NOV 89       Revised Accumulator Spring Chart
289. 90-7-2         NOV 89       Revised Labor Time Guide Format-Auto/Man Trans
290. 907310         OCT 89       (SIR) System Wiring Repair Procedures
291. ATRATB8930     OCT 89       Automatic Transmission Math Part 2
292. 90777A         OCT 89       Check Procedure and Shift Speed 4L60/700-R4 Revised
293. 906810         OCT 89       Hardtop Repair
294. 90753E         OCT 89       Tire Company Warranty Assistance Programs
295. ATRATB8927     SEP 89       20 Steps To successful Auto Transmission Repair
296. 90501D         SEP 89       Air Conditioning Compressor Oval O-Ring Seal
297. ATRATB8928     SEP 89       Fluid Filter Seal
298. 90568          SEP 89       Packard 32 Way Connector Identification
299. ATRATB8923     AUG 89       Automatic Transmission Math Formulas
300. 90496B         AUG 89       Reconstituted Anti-Freeze
301. 90340A         JUL 89       Labor Guide Request For Changes, Feb./June
302. 89970A         MAR 89       Use of Car/Truck Line Indicator In Place of Model Names
303. ATRASIL895     FEB 89       Improved Governor Driven Gear
304. ATRATB8847     NOV 88       Kills Engine In Drive And/Or Reverse - TCC Problem
305. ATRASIL8733    OCT 87       New Auxiliary Accumulator Valve Body - 700R4
306. ATRATB8754     SEP 87       All Automatics - Front Bushing Wear
307. ATRATB8748     AUG 87       Metal Sealing Rings - Automatic Transmissions
308. ATRATB8744     JUL 87       Low And Reverse Clutch Failure - 700R4
309. ATRATB8736     JUN 87       Restricted Exhaust System Check
310. ATRASIL8627    NOV 86       Service Procedures - Oil Pump
311. ATRATB8623     MAY 86       Hidden Residue Build Up - Valves Sticking
312. ATRATB8612     MAR 86       Converter Clutch Shudder
313. ATRATB861      JAN 86       Rapid Pump Bushing Wear
314. ATRATB8524     JAN 85       No Converter Clutch Apply When Unit Is Hot
315. ATRASIL8521    JAN 85       Valve Body Modification - 700R4
316. 81I37          FEB 81       Silica Contamination of Oxygen Sensors
317. 99-09-40-008   JAN 00       AUXILIARY SEAT BELT FOR SECURING CHILD RESTRAINT
318. 99-09-41-004   JAN 00       Air Bag (SIR) On-Off Switch Kits, New Parts and Service
319. 99-09-40-004   JAN 00       TOP TETHER HARDWARE PACKAGE FOR CHILD RESTRAINT SEATS
320. 99-08-66-002A  JAN 00       TRAP RESISTANT REAR COMPARTMENT (TRUNK) KIT
