We are at about 500 m here (1640 ft), at hot idle I see about 30 kPa.
With AutoTap I can't see if the fuel learn is on, or at least I don't know how (do you know if Autotap can do that?)
Your values almost look like your scanner is backwards and not KPA but in inhg
I adjusted the values to fit the LS1Edit IFR table. It's easier to compare / change the values. According to the scanner the pressure is in kPa (??) and not in inHg
