Originally posted by tici:
Is it better to consider LTFT and STFT together?
correction = (LTFT B1 + LTFT B2)/2 + (STFT B1 + STFT B2)/2
This assuming that x% correction for STFT has the same weight for LTFT also
OK, I'll answer myself: see here the result of 2 very long scans (3 hours each, visiting my parents for Easter).
Notice the IFR curves calculated from the LTFT's: they are different.
The other 2 IFR curves are the result of considering LTFT's + STFT's and are the same!
This means (to me) that the formula above (averaged sum of LT and ST) is correct.
As stated by JR LTFT will change only if STFT are higher/lower than +5/-5%. Considering LTFT alone can lead to wrong values (as I personally experienced!).
The 20-30 kPa area is pretty strange confused
I also wonder if and how much the EGR influences the whole story confused
Stefano
