by teamzr1. 12/26/25 03:02 PM
Topics3,718
Posts6,909
#924 - 11/26/05 06:18 PM Fill in the content
OK, years of pushing OBD-II down your throat
Now lt's see in this quiz who can add fill in the content of each image that I slaved long hours to get to you.
Each has a letter assigned so when answering make sure you tell which by the labels your filling in the answers to what each image is showing
Our OBD-II Quiz
#925 - 11/27/05 10:42 AM Re: Fill in the content
I'll start it off however I only have time for a couple before leaving for a few hours.
A:
High speed has been added, i.e. GMLAN.
Battery voltage is now present which removes the need for external power for scan tools.
Signal ground is also available to verify voltage output. ??
C: After test is passed 3 times MIL will be turned off but DTC's, FF and FR will stay in memory until the 40th cycle with no error.
I'll try for more when I get back.
#926 - 12/15/05 09:53 PM Re: Fill in the content
Wow going on 3 weeks and these have not been answered yet ?
Pictures are worth a 1,000 words so should be easy to answer.
I'll give up G.
Any time the PCM has lost power then all the things the PCM has learned about the driving conditions and PCM adjusting for them has been lost.
Being the PCM does Adaptive Learning it could take some days for all the relearns to be done again not only for how the engine is commmanded to run but also the EPA onboard smog tests to re-test and get back to a PASSED state.
Somehow there has to be a way to speed up this relearn process. Consider going to a dealer and they do something, BANG PCM back to a relearn state and next day you have to go in for a smog test but you'd fail since the smog tests are in retest mode again.
Also lets say some shop fixes something because car is failing smog tests. There has to be a easy way for relearns else the shop then could not do the smog tests to see if the repairs solved the failed smog tests
To speed these relearn proces up the PCM has a LEARN process. Image G shows that learn process by following the drive cycle it shows.
PCM sees this drive meets the relearn process and says "ahh" run relearn process now, so if following what is in G the test and relearn are quickly done.
Each part of G is showing what functions get tested/relearned
OK now lets see some of you take a crack at the others and everyone can add more content to what others have posted.
1 registered members (teamzr1), 13 guests, and 9 spiders.
