Topics3,717
Posts6,907
#942 - 02/08/01 08:17 PM '75 and up bulletins
Bulletins for 1975 Chevrolet Corvette V8-350 VIN JT 4-bbl
Emissions Recalls
TSB Number Issue Date TSB Title
1. 75E01 OCT 75 Incorrect Emission Control Label
2. 75E6 MAR 75 Vehicle Emission Control Label
3. 75E02 JAN 75 Emission Control Label - Incorrect
Service Bulletins
1. ATRATB173 JUN 93 Rattling Noise
2. ATRATB097 FEB 92 Bind-Up On 2-3 Shift
3. ATRATB024 SEP 90 Harsh Reverse Engagements
4. ATRATB010 SEP 90 Torque Converter Identification
5. ATRASIL894 FEB 89 Center Support Bolt
6. ATRASIL895 FEB 89 Improved Governor Driven Gear
7. ATRATB8834 JUL 88 Identifying Correct Sprag Rotation - Auto Transmission
8. ATRATB8832 JUL 88 Steel Clutch Piston Inspection
9. ATRATB8824 JUN 88 No Reverse
10. ATRATB8816 MAR 88 No Upshift - Governor Contamination
11. ATRATB887 FEB 88 Checking Pressure Switches For Leaks
12. ATRATB8763 NOV 87 Too Sensitive 3-2 Downshift
13. ATRATB8751 SEP 87 No Torque Converter Clutch Engagement
14. ATRATB8722 APR 87 Second Gear Starts - After Rebuild
15. ATRATB8634 JUL 86 Pressure Tap Locations - Automatic Transmissions
16. ATRATB8622 MAY 86 Cracked Case
17. ATRATB861 JAN 86 Rapid Pump Bushing Wear
18. ATRATB8554 DEC 85 Rear Band Adjustment Too Loose
19. ATRASIL856 JAN 85 Front Pump Interchangeability
20. ATRATB8543 JAN 85 Recurrent Sticking Valves - Automatic Transmission
21. ATRATB8526 JAN 85 Third Gear Switch Shorting on Pan
22. T36 FEB 78 HEI System Description and Diagnosis Chart
#943 - 10/06/05 02:09 PM Re: '75 and up bulletins
Wow! THat's quite a collection of recalls. It makes me glad that we replaced everything in the 74.
1 registered members (teamzr1), 16 guests, and 7 spiders.
