Topics3,614
Posts6,712
Most Online265 Jan 21st, 2023
#6882 - 06/17/25 07:10 AM
Chevry is introducing an all-wheel drive Corvette worthy of the storied ZR1 designation: the 2026 Corvette ZR1X. With 1,250 horsepower1 and electrified all-wheel drive, ZR1X is a true American hypercar and the most advanced Corvette ever. With ZR1 and ZR1X, Chevrolet now has the most powerful American performance car duo of any auto manufacturer.
ZR1X features:
• LT7 twin-turbo V8: 1,064 horsepower at 7,000 rpm, 828 lb-ft of torque at 6,000 rpm • Front-axle motor: 186 horsepower and 145 lb-ft of torque • GM-estimated 0-60: Under 2 seconds • GM-estimated ¼ mile: Under 9 seconds, with trap speed over 150 mph2
“From day one, we designed the mid-engine Corvette architecture with ZR1X in mind,” said General Motors senior VP Ken Morris. “This is the most revolutionary platform in Corvette history, supporting the widest range of American sports cars3 and delivering world-class performance at every level.”
New Corvette ZR1X badge on 2026 Corvette ZR1X in Blade Silver Metallic. Preproduction model shown, actual production model may vary. Otherworldly power, impressive traction
America’s hypercar starts with the ZR1’s LT7 V8, generating more power than any other V8 produced by an American auto manufacturer 1,064 horsepower and 828 lb-ft of torque, sent to the rear wheels through an 8-speed dual-clutch transmission. With a forged flat-plane crankshaft, finger-follower valvetrain, and dry-sump lubrication, this hand-built 5.5-liter Gemini small-block V8 was developed alongside the naturally aspirated flat-plane crankshaft engines powering the Corvette Z06 and Z06 GT3.R race car. This mighty V8 includes:
• Dual 76-mm turbochargers • A “maniturbo” exhaust design that combines the manifold and turbocharger housing to get the turbos as close to the exhaust valves as possible, improving throttle response by decreasing time needed to build boost • Dynamic anti-lag controls that maintain turbo speed when off-throttle in certain situations so boost is available rapidly when throttle is reapplied
Where ZR1 embodies the rear-wheel drive precedent set by prior generations, the Corvette team added all-wheel drive capability for a new take on performance. ZR1X benefits from the foundation set in 2024 by E-Ray, the first-ever AWD Corvette, combining a high-voltage battery pack and electric motor driving the front axle with V8 propulsion turning the rear axle.
There is no physical connection between the two power sources on ZR1X, and the electrified propulsion system does not require a plug-in charging takes place through regenerative efforts from the front drive unit.
ZR1X’s battery pack, located low and centralized within the rigid spine of the chassis, was designed specifically to rapidly cycle between applying bursts of power and charging. This robust pack has been tested at tracks around the world and conquered Corvette’s 24-hour track durability test. While the battery capacity is 1.9 kWh like E-Ray, the usable energy has grown to provide greater lapping capability.
This improvement raises the peak operating voltage, which increases the power output from the front drive unit.
The compact electric motor on the front axle is capable of 186 hp and 145 lb-ft of torque on demand. While retaining the same shape and size of the E-Ray front drive unit, the ZR1X unit pairs strengthened internal components and improvements in energy deployment to generate an additional 26 hp and 20 lb-ft of torque. The front axle is engaged and can apply power through 160 mph before disconnecting, directly benefitting ZR1X’s quarter-mile acceleration stats and on-track balance.
Front 3/4 view of 2026 Chevrolet Corvette ZR1X in Blade Silver Metallic. Preproduction model shown, actual production model may vary.
Two propulsion systems, one mission
The eAWD chassis controls system designed for E-Ray has undergone a significant upgrade for ZR1X. With the benefit of experience on this electrified AWD architecture, the development team applied knowledge from E-Ray to solutions specifically for the LT7’s character and capability. The result is evident in on-road drivability and on-track performance. ZR1X is constantly monitoring driver inputs and vehicle conditions to blend power at both axles for responsiveness and traction management.
On track, ZR1X utilizes specialized energy strategies designed to maximize electrified output based on track session demands and driver preferences: • Endurance – Engaging the Charge+ button adjusts the battery’s energy storage strategy for extended lapping and consistent eAWD output for a full tank of fuel • Qualifying – Optimum power strategy for the ultimate lap time • Push-to-Pass – Max available power on-demand PTM Pro, new for 2026 on all Corvettes, was designed with ZR1X in mind. PTM Pro delivers the purest driving experience. While this setting turns off traction and stability control, the following features remain active: • Regen Brake Torque Vectoring – engineered to recover peak energy without sacrificing agility • Front Axle Pre-Control – actively manages inside front brake pressure to enable maximum corner-exit traction • Launch Control – customizable settings enable rapid acceleration from a rest
Ultimate authority on-road and at the track
The ZR1X balances impressive power with robust brakes specifically developed with this car in mind. The J59 braking package, standard on ZR1X and an option on ZR1, is a clean-sheet design intended for superior heat resistance and ultra-responsive braking.
Alcon 10-piston front and 6-piston rear calipers are mated to 16.5-inch front and rear rotors the largest diameter rotors ever offered on Corvette. The rotors are carbon ceramic, constructed with continuously woven carbon fiber threads.
This is the most resilient production car braking system we’ve tested within GM. And during testing, we saw J59-equipped Corvettes achieve 1.9G of deceleration from 180 to 120 mph. ZR1X is offered in two chassis configurations that both feature magnetic ride control adjusting to the vehicle’s mode, driver inputs and the road surface for optimal control. The standard chassis, accompanied by Michelin PS4S tires, makes for a comfortable touring car on-road and a highly capable Corvette at the track. The available ZTK Performance Package incorporates higher spring rates and is firmer. Paired with the grip of Michelin’s Pilot Cup 2R tires, this is the pinnacle of Corvette performance.
Customers can equip the high-downforce Carbon Aero package to a standard chassis ZR1X, adding dive planes, underbody strakes, a hood gurney lip over the front heat extractor and a highly effective rear wing. This package is capable of 1,200 lbs of downforce at top speed and comes standard on ZTK-equipped cars.
The pinnacle of Corvette performance
The 2026 Corvette ZR1X is the ultimate expression of the no-compromise eighth generation platform. It’s an all-day comfortable tourer, a straight-line rocket, and a racetrack weapon, all in one. Like every iconic sports car in the Corvette lineup, ZR1X will be available in coupe or hardtop convertible body style. ZR1X enters the market with Corvette’s fresh interior, revealed last month.
A new three-screen layout and reimagined console design, real-time vehicle data provided by the built-in Performance App, and new colors and high-quality materials all highlight the 2026 Corvette interior.
Every ZR1X will be proudly built in America at General Motors’ Bowling Green Assembly Plant in Kentucky from U.S. and globally sourced parts, with every LT7 engine hand-assembled by the master engine builders at the Bowling Green Performance Build Center. Further details on price and availability will be shared closer to production.
11,064 horsepower from the LT7 5.5L V8 engine, plus 186 horsepower from the eAWD (electric drive unit). 2On a closed course only. Based on initial vehicle movement. 3Assembled in Bowling Green, Kentucky of U.S. and globally sourced parts.
#6883 - 06/17/25 07:24 AM
Re: GM Release info on C8 ZR1X
[Re: teamzr1]
#6885 - 06/18/25 09:56 AM
[Re: teamzr1]
#6889 - 06/19/25 06:24 PM
[Re: teamzr1]
#6890 - 06/20/25 07:49 AM
[Re: teamzr1]
A GM website for the 2026 C8 Corvette ZR1X that has detail of this Corvette Can sign up there for GM to email you updates ZR1X Website
#6910 - 07/04/25 02:51 PM
[Re: teamzr1]
Chevrolet just announced the most powerful, most advanced Corvette ever created: The 2026 ZR1X. This vehicle takes the 1,064-horsepower V8 engine from the eighth-generation ZR1 and pairs it with an electrified front-axle motor to create an all-wheel-drive Corvette with 1,250 combined horsepower1. Here are five things you need to know about this true American hypercar2.
Unheard-of power
The heart of the Corvette ZR1X is the LT7 engine. This twin-turbo 5.5-liter V8 shares its flat-plane-crank, dual-overhead-cam architecture with the naturally-aspirated LT6 that powers the Corvette Z06. Together, these engines are known as the “Gemini twins.” Dual 76-mm turbochargers help the LT7 generate 1,064 horsepower, making it the most powerful V8 engine ever produced in America from an auto manufacturer.
For ZR1X, Corvette engineers took the power to the next level by adding all-wheel drive. The front-axle e-motor first seen on the all-wheel-drive Corvette E-Ray was thoroughly revamped to generate an additional 26 horsepower and 20 lb-ft of torque, for a total of 186 horsepower and 145 lb-ft at the front axle – and 1,250 horsepower combined.
Unprecedented Corvette acceleration
With more power than any Corvette before it, combined with all-wheel traction, the ZR1X was built to deliver acceleration that challenges what you thought was possible. On a closed course, GM engineers estimate that ZR1X will sprint from zero to 60 mph in less than 2 seconds3, and blast through the quarter mile in under 9 seconds3. Enabling this otherworldly acceleration required some unexpected changes. In the Corvette E-Ray, the front-axle e-motor disconnects at 150 mph – but in the ZR1X, that disconnect speed was increased to 160 mph to make front-axle power available throughout a quarter-mile drag strip run.
Unbelievable brakes
When you’ve got hypercar acceleration, you need stopping power to match. Corvette ZR1X introduces the largest diameter rotors ever offered on Corvette, and the most resilient production car braking system ever tested within GM. The J59 braking system, standard on every ZR1X, features 16.5-inch carbon-ceramic brake rotors at all four wheels, gripped by 10-piston front and six-piston rear calipers.
The rotors are composed of continuously woven carbon fiber threads, and the overall braking package is a clean-sheet design intended for superior heat resistance and ultra-responsive braking. During racetrack testing, a J59-equipped Corvette recorded 1.9G of deceleration from 180 mph to 120 mph.
Power strategies for race-track dominance
Every Corvette is engineered for consistent performance at the race track. With an e-axle up front and the LT7 V8 driving the rear, ZR1X needed advanced powertrain controls. Power can be deployed using three distinct strategies: Endurance, which strategically manages battery power to deliver consistent eAWD output for a full tank of fuel; Qualifying, which cranks out optimum power for the ultimate lap time; and Push-to-Pass, which delivers maximum available power on demand.
Uncompromised capability on the road or the racetrack
Perhaps the most impressive aspect of ZR1X is its well-rounded capability. At the drag strip, it’s a straight-line rocket. On the racetrack, it’s a corner-carving weapon. And on the highway, this hypercar offers the luxurious all-day comfort that owners love about the eighth-generation Corvette. The 2026 ZR1X will debut with Corvette’s newly redesigned interior, featuring expanded instrumentation plus custom configurations never before offered in the Corvette lineup. ZR1X is the ultimate expression of the no-compromises C8 platform, available in coupe or hardtop convertible, with the optional high-downforce ZTK aero package available on either configuration. See Chevy.com for details and expected availability.
1, 1,064 horsepower from the LT7 5.5L V8 engine, plus 186 horsepower from the eAWD (electric drive unit). 2 Assembled in Bowling Green, Kentucky of US and globally sourced parts. 3 On a closed course only. Based on initial vehicle movement.
0 registered members (),
12
guests, and
15
spiders. |
Admin,
Global Mod,
