Rear Differential Clutch Pack Stack Height Change - keywords axle bind chatter shudder #PIP3892A - (09/11/2006)
Models: 2007 Cadillac XLR
2006-2007 Chevrolet Corvette Z06
Condition/Concern:
When replacing the rear differential clutch packs in a 2006-2007 Chevrolet Corvette Z06 or 2007 Cadillac XLR, technicians may find a 5 plate clutch pack, also eSI will call for a 5 plate pack, but service parts come as a 4 plate pack.
Recommendation/Instructions:
A change to carbon fiber clutch plates in the above models which increased overall thickness makes it necessary to reduce the stack to a 4 plate pack. The correct stack using the new designed plates will be a 4 plate pack and will not effect performance.
Note: This change does not apply to the normal Corvette or XLR-V.
