STAT SHAFT c5
by teamzr1. 06/20/25 07:49 AM
07/09/02
11:00 AM
STAT SHAFT c5
I WOULD LIKE TO MAKE A THERM SHIM BEFORE I REMOVE THE THERMOSTAT. Does anyone know the diameter of the shaft.
07/09/02
02:32 PM
Re: STAT SHAFT c5
Have you read the other writeup I did on team website at :
Installing the mod
If you do not want to make shims, use small washers or some even have used the head cut off a screw.
About 3/16 diameter
07/09/02
03:08 PM
Re: STAT SHAFT c5
tnanks, this is little known info.
0 registered members (), 8 guests, and 17 spiders.
C8 ZR1-X Brake Design
by teamzr1. 06/19/25 03:02 PM
47,709
47,190
44,182
39,881
34,962
30,754
25,786
24,032
Newest DCT Fluid Types
by teamzr1. 06/04/25 06:38 PM
