#1974 - 09/05/0704:37 PMCan a Tune Help IF Car is Stock ?
Joined: Dec 2000 Posts: 5,869teamzr1 Owner - Pays the bills
The short answer isyes.
GM works on a 80% design rule and has to have a engine calibration that no matter what Type of gas is used, Where car is located Type of weather and Type of driver and how car is driven
For this example we compare a stock GM calibration and one we tuned in a 2001 Z06.
Review that values and results below but at the least if the stock timing is only increased 4 degrees of timing with other functions properly tuned you see higher performance, engine taking in more air and still even less knock occuring.
So even if the engine is stock a custom tune will gain the performance and reduce issues such as knock and misfire so performance is not lost during those conditions
