Topics3,615
Posts6,713
#3058 - 05/19/09 10:32 AM Tuner - RPM - Charlie
We have seen quite a few screwed up C6s but the owner Charlie of a shop in the LA Ca area that is one of the worst out there.
We personally have had to retune about 6 C6 Z06s he has hacked on.
Latest is a 2006 Z06 for whatever the reason sucked the owner into buying a new LS7 and ole Charlie then hacked on.
In part was also his so called "dyno tuning"
The owner lives in Oregon which means the cost and time to round trip and on the drive back from RPM the car died several times and also had starting problems. puke
Owner came over and the first thing we did was download the PCM and examine the so called tune Charlie did and it really makes me pissed to see how a car worth about $60,000 is hacked on like it was a 2000 Toy ota POS.
Here we see he turned off almost ALL DTC error codes to hide problems and to prevent anyone knowing when there is engine problems.
Type X = turned off = P0010 Camshaft Position (CMP) Actuator Solenoid Control Circuit
Type X = turned off = P0011 Camshaft Position (CMP) System Performance
Type X = turned off = P0069 MAP - Barometric Pressure Correlation
Type X = turned off = P0125 ECT Excessive Time To Closed Loop Fuel Control
Type X = turned off = P0169 Fuel Composition Sensor
Type X = turned off = P0178 Fuel Composition Sensor Low Voltage
Type X = turned off = P0179 Fuel Composition Sensor High Voltage
Type X = turned off = P0231 Fuel Pump Control Circuit Low Voltage
Type X = turned off = P0232 Fuel Pump Control Circuit High Voltage
Type X = turned off = P023A Unknown
Type C = No MIL Light = P0300 Engine Misfire Detected
Type X = turned off = P0401 EGR Performance
Type X = turned off = P0404 EGR Pintle Position Error
Type X = turned off = P0405 EGR Pos Sensor Low Volt
Type X = turned off = P0412 AIR Solenoid Relay Control Circuit
Type X = turned off = P0418 AIR Pump Relay Control Circuit
Type X = turned off = P0480 Cooling Fan Relay 1 Control Circuit
Type X = turned off = P0481 Cooling Fan Relay 2 Control Circuit
Type X = turned off = P0482 Cooling Fan Relay 3 Control Circuit
Type X = turned off = P0483 Cooling Fan Check Fail
Type X = turned off = P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent
Type X = turned off = P0513 Theft Deterrent Key Incorrect
Type X = turned off = P0521 Engine Oil Pressure (EOP) Sensor Performance
Type C = No MIL Light = P0562 System Voltage Low
Type C = No MIL Light = P0563 System Voltage High
Type X = turned off = P0567 Cruise Control Resume Switch Circuit
Type X = turned off = P0568 Cruise Control Set Switch Circuit
Type C = No MIL Light = P0572 Brake Switch Circuit 1 Low Voltage
Type C = No MIL Light = P0573 Brake Switch Circuit 1 High Voltage
Type C = No MIL Light = P0575 Cruise Control Switch Signal Circuit
Type C = No MIL Light = P0607 Control Module Performance
Type C = No MIL Light = P0608 Vehicle Speed Output Circuit
Type X = turned off = P0609 Vehicle Speed Output Circuit 2
Type X = turned off = P0615 Starter Relay Control Circuit
Type C = No MIL Light = P0621 Generator L-Terminal Circuit
Type C = No MIL Light = P0622 Generator F-Terminal Circuit
Type A = MIL on 1st error = P062F Control Module EEPROM Error
Type X = turned off = P0633 Theft Deterrent Key Not Programmed
Type C = No MIL Light = P0645 Air Conditioning (A/C) Clutch Relay Control Circuit
Type C = No MIL Light = P0654 Engine Speed Output Circuit
Type X = turned off = P0700 Transmission Control Module (TCM) Requested MIL Illumination
Type C = No MIL Light = P0703 Unknown
Type C = No MIL Light = P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Voltage
Type C = No MIL Light = P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Voltage
Type X = turned off = P0719 Brake Switch Circuit Low Voltage
Type X = turned off = P0724 Brake Switch Circuit High Voltage
Type C = No MIL Light = P0801 Reverse Inhibit Solenoid Control Circuit
Type X = turned off = P0806 Clutch Pedal Posit. Sens Circuit Performance
Type X = turned off = P0807 Clutch Pedal Posit. Sens Circuit Low Voltage
Type X = turned off = P0808 Clutch Pedal Posit. Sens Circuit High Voltage
Type C = No MIL Light = P0831 Unknown
Type B = MIL on 2nd error = P0833 Clutch Pedal Switch 2 Circuit
Type C = No MIL Light = P0856 Traction control Torque Request Circuit
Type X = turned off = P1106 MAP Intermittent High
Type X = turned off = P1107 MAP Intermittent Low
Type X = turned off = P1111 IAT Sensor Circuit Intermittent High Voltage
Type X = turned off = P1112 IAT Sensor Circuit Intermittent Low Voltage
Type X = turned off = P1114 ECT Sensor Circuit Intermittent Low Voltage
Type X = turned off = P1115 ECT Sensor Circuit Intermittent High Voltage
Type C = No MIL Light = P1380 Misfire Detected - Rough Road Data Type C = No MIL Light = P1381 Misfire Detected - No Communication With Brake Control Module
Type X = turned off = P1400 Cold Start Emission Reduction Control System
Type X = turned off = P1404 EGR Pintle Closed Position Performance
Type X = turned off = P1574 Stop Lamp Switch Circuit
Type X = turned off = P1575 Extended Travel Brake Sw. Circuit High Voltage
Type X = turned off = P1629 Theft Deterrent Fuel Enable Signal Not Received
Type C = No MIL Light = P1630 Theft Deterrent Learn Mode Active
Type C = No MIL Light = P1631 Theft Deterrent Fuel Enable Signal Not Correct
Type X = turned off = P1632 Theft Deterrent Fuel Disable Signal Signal Received
Type X = turned off = P1652 PCM Chassis Pitch Output Circuit (w/message)
Type X = turned off = P1668 Generator L-Terminal Control Circuit
Type X = turned off = P1689 Traction Control Delivered Torque Control Circuit
Type X = turned off = P2534 Ignition 1 Switch Circuit Low Voltage
Type X = turned off = P2544 Transmission Torque Request Circuit
Type X = turned off = P2632 Fuel Pump Relay 2 Control Circuit
Type C = No MIL Light = P2636 Fuel Transfer Pump Flow Insufficient
Type X = turned off = P2A00 HO2S Circuit Bank 1 Sensor 1
Type X = turned off = P2A03 HO2S Performance Bank 2 Sensor 1
Type X = turned off = P3400 Cylinder Deactivation System Performance
Type X = turned off = P3401 Cylinder 1 Deactivation Solenoid Control Circuit
Type X = turned off = P3425 Cylinder 4 Deactivation Solenoid Control Circuit
Type X = turned off = P3441 Cylinder 6 Deactivation Solenoid Control Circuit
Type X = turned off = P3449 Cylinder 7 Deactivation Solenoid Control Circuit
Type X = turned off = X1207
Type X = turned off = X1208
Type X = turned off = X1209
Type X = turned off = X1210
Type X = turned off = X1221
Type X = turned off = X1222
Type X = turned off = X1223
Type X = turned off = X1224
Type X = turned off = X1225
Type X = turned off = X1226
Type X = turned off = X1227
Type X = turned off = X1228
Type X = turned off = X1232
Type X = turned off = X1233
Type X = turned off = X1234
Type X = turned off = X1235
Type X = turned off = X1255
Type X = turned off = X1256
Type C = No MIL Light = U0073 High Speed CAN Communication Bus
Type X = turned off = U0100 Lost Communications with Engine Control Module (ECM)
Type X = turned off = U0101 Lost Communication With Transmission Control Module (TCM)
Type X = turned off = U0104 Lost Communication With Cruise Control Module
Type C = No MIL Light = U0121 Lost Communication With Brake Control Module (EBCM)
Type X = turned off = U0140 Lost Communication With Body Control Module (BCM)
Type X = turned off = U0164 Lost Communication With HVAC Module
Type X = turned off = U1041 Lost Communications With Electronic Brake Control Module (EBCM)
Type X = turned off = U1064 Lost Communications With Body Control Module (BCM)
Type X = turned off = U1088 Lost Communications With Inflatable Restraint Sensing and Diagnostic Module (SDM)
Type X = turned off = U1096 Lost Communications With Instrument Panel Cluster (IPC)
Type X = turned off = U1152 Lost Communications With HVAC Control Module
Type X = turned off = U1300 Class 2 Data Link Low
Type X = turned off = U1301 Class 2 Data Link High
Pretty low life to do crap like this.
Images of parts of his tune below.
Included we found
1. Torque management turned off.
2. Misfire turned off.
3. MAF table values screwed up.
4. Weird timing table values for both high and low octane
5. So called ported the stock throttlebody, was done badly causing the random idle on decel and bad startups
6. with the costs of new LS7, porting, valve springs, Vararam the end results was ZERO gain and the tune was lousy.
Reason engine was replaced is a radical CAM installed caused valves to smash into the cylinders
Attached Files LS7piston2.jpgLS7piston3.jpgmisfireoff.jpgidletiming.jpgMAFdiff.jpg
#3059 - 05/19/09 10:34 AM Re: Tuner - RPM - Charlie [Re: teamzr1]
Compare via a testrun with scanner shows zero and maybe even a bit less before RPM/Charlie work, mods and his tune.
0 registered members (), 15 guests, and 15 spiders.
