2008 Chevrolet Corvette TSB
1 TSB No.:PIP-4395 NHTSA No.:10026149 TSB Date:August 1, 2008 Date Added to File:October 2, 2008
Failing Component:
Power Train:Automatic Transmission
Summary:
GMC: flare and or harsh 2-3 shifts. This condition may be caused by leaking 1-2-3-4 and 3-5-r clutch fluid seal rings (230). Models cadillacs, chevrolets, GMC, hummers, pontiacs. Equipped with 6l80 (rpo myc) or 6l90 (rpo myd) automati
2 TSB No.:08-05-25-004 NHTSA No.:10026002 TSB Date:July 1, 2008 Date Added to File:September 23, 2008
Failing Component:
Service Brakes, Air:Antilock:Abs Warning Light
Summary:
GMC: antilock brake system (abs), traction control system (tcs) or stabilitrak light on, DTCs C0035-C0052 set (perform diagnostic component test procedure and repair as necessary).
3 TSB No.:08-05-25-004 NHTSA No.:10026002 TSB Date:July 1, 2008 Date Added to File:September 23, 2008
Failing Component:
Summary:
4 TSB No.:08-05-25-004 NHTSA No.:10026002 TSB Date:July 1, 2008 Date Added to File:September 23, 2008
Failing Component:
Service Brakes, Hydraulic:Antilock:Control Unit/Module
Summary:
5 TSB No.:08-07-30-021 NHTSA No.:10025668 TSB Date:May 1, 2008 Date Added to File:August 28, 2008
Failing Component:
Digital Instrument Panel
Summary:
Loss of high speed gmlan communications, intermittent no crank, ipc gauge fluctuation, intermittent door lock cycling, transmission may not shift, DTCs U0073, U0100, U0101, U0102, U0121, U0140 set (repair backed out terminal in transmission
6 TSB No.:08-07-30-021 NHTSA No.:10025668 TSB Date: May 1, 2008 Date Added to File: August 28, 2008
Failing Component:
Latches/Locks/Linkages: Doors:Latch
Summary:
7 TSB No.:08-07-30-021 NHTSA No.:10025668 TSB Date: May 1, 2008 Date Added to File: August 28, 2008
Failing Component:
Power Train:Automatic Transmission: Control Module (Tcm, Pcm)
Summary:
8 TSB No.:08-07-30-021 NHTSA No.: 10025668 TSB Date:May 1, 2008 Date Added to File: August 28, 2008
Failing Component:
Summary:
9 TSB No.:08-07-30-021 NHTSA No.:10025668 TSB Date:May 1, 2008 Date Added to File:August 28, 2008
Failing Component:
Engine And Engine Cooling:Engine
Summary:
10 TSB No.:PIC-4868 NHTSA No.:10025666 TSB Date:May 1, 2008 Date Added to File:August 28, 2008
Failing Component:
Electronic Stability Control
Summary:
Abs, traction control, or stability tell tales on (DTC C0035-C0052). The abs, traction control, or service stability system (if equipped) warning telltales illuminate.
11 TSB No.:PIC-4868 NHTSA No.:10025666 TSB Date:May 1, 2008 Date Added to File:August 28, 2008
Failing Component:
Summary:
12 TSB No.:PIC-4868 NHTSA No.:10025666 TSB Date:May 1, 2008 Date Added to File:August 28, 2008
Failing Component:
Suspension:Automatic Stability Control (Asc)
Summary:
13 TSB No.:08-07-30-021 NHTSA No.:10025402 TSB Date: April 1, 2008 Date Added to File:August 6, 2008
Failing Component:
Summary:
Loss of high speed gmlan communications, intermittent no crank, ipc gauge fluctuation, intermittent door lock cycling, transmission may not shift, DTCs U0073, U0100, U0101, U0102, 70140 (repair backed out terminal in transmission harness co
14 TSB No.:08-07-30-021 NHTSA No.:10025402 TSB Date:April 1, 2008 Date Added to File:August 6, 2008
Failing Component:
Latches/Locks/Linkages: Doors: Latch
Summary:
15 TSB No.:08-07-30-021 NHTSA No.:10025402 TSB Date:April 1, 2008 Date Added to File:August 6, 2008
Failing Component:
Power Train:Automatic Transmission:Control Module (Tcm, Pcm)
Summary:
Loss of high speed gmlan communications, intermittent no crank, ipc gauge fluctuation, intermittent door lock cycling, transmission may not shift, DTCs U0073, U0100, U0101, U0102, 70140 (repair backed out terminal in transmission harness co 16 TSB No.:08-07-30-021 NHTSA No.:10025402 TSB Date:April 1, 2008 Date Added to File:August 6, 2008
Failing Component:
Summary:
17 TSB No.:08-08-64-001 NHTSA No.:10025125 TSB Date:April 1, 2008 Date Added to File:July 11, 2008
Failing Component:
Visibility:Power Window Devices And Controls
Summary:
Ei08034 - power window/regulator concerns, inoperative, intermittent, indexing, continuous up and down (diagnose door handle switch, replace if necessary).
18 TSB No.:PIP4304 NHTSA No.:10024346 TSB Date:February 1, 2008 Date Added to File:April 7, 2008
Failing Component:
Power Train:Manual Transmission
Summary:
DTC P0878, P2714, P2723, transmission slips in 1st, 2nd, 3rd, or 4th gears and/or long garage shifts to drive, equipped with a 6l50 (myb), 6l80 (myc), or 6l90 (myd) transmission.
19 TSB No.:PIC4765 NHTSA No.:10024269 TSB Date:February 1, 2008 Date Added to File:March 31, 2008
Failing Component:
Fuel System, Other:Storage:Fuel Gauge System
Summary:
Erratic fuel gauge operation DTC's P2066 and/or P2636.
20 TSB No.:PIC4765 NHTSA No.:10024209 TSB Date: February 1, 2008 Date Added to File:March 24, 2008
Failing Component:
Summary:
21 TSB No.:070495001 NHTSA No.:10023935 TSB Date: October 1, 2007 Date Added to File:February 19, 2008
Failing Component:
Wheels:Lugs/Nuts/Bolts
Summary:
Tapping or scraping noise from rear wheel area (replace wheel drive shaft nut).
22 TSB No.:4702 NHTSA No.:10023860 TSB Date: December 1, 2007 Date Added to File:February 7, 2008
Failing Component:
Exterior Lighting:Fog Lights
Summary:
Fog lamps inoperative with approach lights on.
23 TSB No.:4269 NHTSA No.:10023859 TSB Date: December 1, 2007 Date Added to File:February 7, 2008
Failing Component:
Power Train:Clutch Assembly:Pedal/Linkage
Summary:
Clutch pedal sticks to the floor and will not return - on a manual transmission. Updated 2/27/08.
24 TSB No.:4292 NHTSA No.:10023772 TSB Date: December 1, 2007 Date Added to File:January 31, 2008
Failing Component:
Summary:
DTC P0756, P0796, P2714, P2723, tcc shudder or harsh engagement, harsh shifts, water in transmission - keywords code converter fluid torque. Equipped with 6l50, 6l80 or 6l90 (rpo's myb, myc, myd) automatic transmission.
25 TSB No.:4302 NHTSA No.:10023771 TSB Date: December 1, 2007 Date Added to File:January 31, 2008
Failing Component:
Power Train:Automatic Transmission:Torque Converter
Summary:
DTC P0751, P0756, P0776, P0796, P2714, P2723, harsh tcc engagement. Equipped with 6l80 (rpo myc) automatic transmission.
26 TSB No.:4678 NHTSA No.:10023737 TSB Date: December 1, 2007 Date Added to File:January 29, 2008
Failing Component:
Unknown Or Other
Summary:
Pop or creak noise from rear of vehicle behind the seats.
27 TSB No.:4426 NHTSA No.:10023729 TSB Date: December 1, 2007 Date Added to File:January 29, 2008
Failing Component:
Exterior Lighting:Tail Lights
Summary:
Center high mount stop lamp illuminates dim all the time.
28 TSB No.:07260 NHTSA No.:10023580 TSB Date: January 1, 2008 Date Added to File:January 9, 2008
Failing Component:
Electrical System:Ignition:Module
Summary:
Keyless access system inoperative on certain 2008 chevrolet corvette. Csc was received. Updated 3/13/08.
29 TSB No.:4112 NHTSA No.:10023432 TSB Date: July 1, 2008 Date Added to File: December 11, 2007
Failing Component:
Summary:
Sag or hesitation on acceleration (normal operating characteristics). Equipped w/ gasoline engine and automatic transmission. Updated 1/30/08. Updated 10/01/08.
30 TSB No.:4624 NHTSA No.:10023421 TSB Date: October 1, 2007 Date Added to File: December 10, 2007
Failing Component:
Exterior Lighting:Headlights
Summary:
Fine cracks or crazing on head lamp lens.
31 TSB No.:4052 NHTSA No.:10022794 TSB Date:n/a Date Added to File: September 27, 2007
Failing Component:
Summary:
2-3 upshift slip or flare.
32 TSB No.:070420002 NHTSA No.:10022263 TSB Date: January 1, 2008 Date Added to File: July 24, 2007
Failing Component:
Power Train: Driveline: Differential Unit
Summary:
Rear axle clunk and/or chatter type noise on turns (drain/refill rear differential fluid). Updated 4/11/08.
33 TSB No.:4011 NHTSA No.:10020881 TSB Date: December 13, 2007 Date Added to File: January 25, 2007
Failing Component:
Air Bags
