Component Description:
1. POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Bulletin Number: PIP-4653B
Bulletin Date: Sep 2009
Vehicle: 2,009 Chevrolet Corvette
Summary:
BUICK/CHEVROLET/HUMMER/GMC/PONTIAC/CADILLAC/SATURN: TECHNICIANS MAY FIND DTCS P0601, P0603, P0604, P062F OR P1621 STORED IN THE TCM AS AN ACTIVE OR A HISTORY CODE. SOME OF THESE DTCS CAN ALSO BE SET IN THE ECM OR FPCM. MAKE SURE THAT YOU ( NHTSA ITEM NUMBER - 10032434 )
2. FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY
Bulletin Number: PIC-5104A
Bulletin Date: Apr 2009
Summary:
GENERAL MOTORS: FUEL SYSTEM DTC'S P2066, P2636. A COMMENT MADE ON THE ACCURACY OF THE FUEL GAUGE. IN SOME RARE CASES, THEY MAY COMMENT THAT THE VEHICLE RUNS OUT OF FUEL AT APPROX. 1/4 TANK. ( NHTSA ITEM NUMBER - 10030426 )
3. AIR BAGS
Bulletin Number: SB-08-09-41-
Bulletin Date: Feb 2009
Summary:
GENERAL MOTORS: DIAGNOSTIC INFORMATION FOR INTERMITTENT RESTRAINTS, AIR BAG (SIR) INDICATOR/LAMP ON WITH DTC(S) B0012, B0013, B0016, B0016, B0019, B0020, B0022, B0023, B0026, B0033, B0040, B0042 OR B0044 SET. THIS MAY BE CAUSED BY A LOOSE, ( NHTSA ITEM NUMBER - 10029924 )
4. FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY
Bulletin Number: PIC-5049
Bulletin Date: Dec 2008
Summary:
CHEVROLET: FUEL TANK HARD TO FILL OR DISPLAYS 1/2 TANK AFTER FILLING. ( NHTSA ITEM NUMBER - 10028176 )
5. FUEL SYSTEM, OTHER:STORAGE:TANK ASSEMBLY
Summary:
6. FUEL SYSTEM, OTHER:STORAGE:TANK ASSEMBLY:FILLING/CHARGING
Summary:
7. ELECTRICAL SYSTEM:WIRING
Bulletin Number: TSB-08259A
Bulletin Date: Nov 2008
Summary:
GMC: ONSTAR SYSTEM INOPERATIVE; REPLACE ONSTAR MODULE. SOME VEHICLES MAY HAVE AN ONSTAR MODULE WITH A COMPONENT THAT WAS NOT MANUFACTURED TO GM'S SPECIFICATION. CAN RESULT IN AN OPEN CIRCUIT AND AN INABILITY TO CALL OR RECEIVE CALLS FROM ON ( NHTSA ITEM NUMBER - 10028179 )
8. EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM)
Summary:
9. ELECTRICAL SYSTEM
Bulletin Number: PIT-4665A
Summary:
GENERAL MOTORS: DURING NORMAL DIAGNOSTICS AND/OR REPAIR VERIFICATION THE ABS LIGHT, TRACTION CONTROL AND/OR STABILITRAK INDICATORS MAY BE ON WITH NO DTC'S DISPLAYED BY THE EBCM. ( NHTSA ITEM NUMBER - 10028264 )
10. EQUIPMENT:ELECTRICAL
Summary:
11. ELECTRICAL SYSTEM: SOFTWARE
Summary:
12. ELECTRONIC STABILITY CONTROL
Summary:
13. EQUIPMENT:OTHER:OWNERS/SERVICE/OTHER MANUAL
Bulletin Number: 08-259
Bulletin Date: Sep 2008
Summary:
GMC: ONSTAR SYSTEM INOPERATIVE - REPLACE ONSTAR MODULE. THIS CAN RESULT IN AN OPEN CIRCUIT AND AN INABILITY TO CALL OR RECEIVE CALLS FROM ONSTAR. CSC LETTER WAS RECEIVED. ( NHTSA ITEM NUMBER - 10026693 )
14. POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Number: PIP-4395
Bulletin Date: Aug 2008
Summary:
GMC: FLARE AND OR HARSH 2-3 SHIFTS. THIS CONDITION MAY BE CAUSED BY LEAKING 1-2-3-4 AND 3-5-R CLUTCH FLUID SEAL RINGS (230). MODELS CADILLACS, CHEVROLETS, GMC, HUMMERS, PONTIACS. EQUIPPED WITH 6L80 (RPO MYC) OR 6L90 (RPO MYD) AUTOMATI ( NHTSA ITEM NUMBER - 10026149 )
15. SUSPENSION:AUTOMATIC STABILITY CONTROL (ASC)
Bulletin Number: PIT4162
Bulletin Date: Jul 2008
Summary:
SERVICE STABILITY LAMP DTC C0131. ( NHTSA ITEM NUMBER - 10022693)
