ENGINE Type: LT5 6.2L Supercharged V-8 with direct and port injection Bore & stroke (in / mm): 4.06 x 3.62 / 103.25 x 92 Block material: Cast aluminum Cylinder head material: Cast aluminum Valvetrain: Overhead valve, two valves per cylinder Fuel delivery: Direct and port injection Horsepower (hp @ rpm): 755 @ 6300 rpm (SAE certified) Torque (lb.-ft. @ rpm): 715 @ 4400 rpm (SAE certified)
TRANSMISSION & AXLE Type: 7-speed manual with Active Rev Match 8-speed paddle-shaft automatic Final Drive Ratio: 3.42 (manual) 2.41 (automatic)
CHASSIS & SUSPENSION Front Suspension: Short/long arm (SLA) double wishbone, cast aluminum upper and lower control arms, transverse-mounted composite spring, Magnetic Selective Ride Control Rear Suspension: Short/long arm (SLA) double wishbone, cast aluminum upper and lower control arms, transverse-mounted composite spring, Magnetic Selective Ride Control Steering Type: Variable-ratio rack-and-pinion with electric power assist Turning Circle (ft. / m): 39.2 / 11.6 Brake Type: Front and rear power-assisted discs with two-piece carbon ceramic matrix rotors; fixed six-piston aluminum front calipers and fixed four-piston aluminum rear calipers Brake Rotor Size (in / mm): Front –15.5 / 394 Rear –15.3 / 388 Wheel Size: Front: 19-inch x 10.5-inch Rear: 20-inch x 12-inch Tire Size: Michelin Pilot Super Sport run-flat (std.) Michelin Pilot Sport Cup 2 (ZTK) Front: P285/30ZR19 Rear: P335/25ZR20
