C5 RPO codes
AAB Memory, Driver Convenience Package
AK5 Inflatable Restraint System, Driver and Passenger
AQ9 Reclining Bucket Seat, Driver and Passenger
AR9 Reclining Bucket Seat, Driver and Passenger, European Style
AX4 Conversion, Seat Belt, Manual, European
BAG Parts Package, Export
BCC Cylinder Unit Passenger Door
BGR Plant Code Bowling Green, KY, USA
BW3 Bumper Provisions Canadian Requirements
B4H Modification Noise Control, Export
B84 Molding B/S Exterior
CC3 Roof Panel, Removable
CF7 Roof Panel, Removable
CJ2 HVAC System, Air Conditioning, Automatic Temperature Control
C05 Roof, Convertible Folding
C2L Roof Package, Dual Removable
DD0 Mirror, Outside, LH & RH, Remote Control, Electric, Heated, Light Sensitive
DD8 Mirror, Inside, R/V Light Sensitive
DL5 Decal Roadside Service Information
DL8 Mirrors, Outside, LH/RH Remote Control Electric, Heated
D24 Mirror O/S LH and RH,Remote Control, Electric, Heated LT Sensitive, Power Folding
ECM Module Inflatable Restraint, European Complaint
FE1 Suspension System
FE3 Suspension System, Sport
FE4 Suspension System, Special Ride and Handling
F45 Chassis, Continuously Variable, Real Time Damping
F55 Chassis Continuously Variable Real Time Damping Magneto Rheological
GU2 Axle, Rear, 2.73 Ratio
GU6 Axle, Rear, 3.42 Ratio
G90 Axle, Rear, 3.15 Ratio
G92 Axle, Rear, Performance Ratio
JL9 Brake System, Power, Front & Rear Disc, Antilock, 4 Wheel
KG4 Generator 150 AMP
K05 Heater, Engine Block
K63 Generator, 110 Amp
LMS Ornamentation Emblem Lemans 3RD GTS WIN
LS1 Engine, Gas, 8 Cylinder, 5.7L, SFI, Aluminum
LS6 Engine, Gas, 8 Cylinder, 5.7L, SFI, Aluminum HO
MM6 Transmission, Manual 6 Speed, 85 mm, 2.66 1st, 0.50 6th, O/D
MN6 Merchandised Transmission, Manual 6 Speed Provisions
MX0 Merchandised Transmission, Automatic O/D Provisions
M12 Transmission, Manual 6 Speed, 85 mm, 2.97 1st, 0.57 6th, O/D
M30 Transmission, Automatic 4 Speed, 4L60 E, Electronic
NA3 Emission System, Japan
NC1 Emission System, California LEV
NF9 Emission System Federal, NLEV
NK4 Steering Wheel, Sport Leather
NP7 Steering Column, EEC Approved
NT3 Emission System EEC 00
N37 Steering Column, Tilt, Telescoping
N73 Wheel Custom Sport, VAR 4
N73 Wheel, Custom Sport Magnesium
P12 Wheel 17 x 9.5 Front and 18 x 10.5 Rear, Cast Aluminum
P36 Wheel 17 X 9.5 FRT and 18 x 10.5 RR, Alum Polished
QD4 Wheel 17 x 8.5 Front and 18 x 9.5 Rear, Aluminum, Styled
QF5 Wheel, 17.0 x 8.5" Front and 18.0 x 9.5" Rear, Aluminum, Polished
QG1 Wheel, 17.0 x 8.5" Front and 18.0 x 9.5" Rear, Aluminum, Painted
RPA Rear Parking Assist
T2F Brake Provisions Special
T82 Headlamp Control, Automatic On Off
T84 Headlamps, RH Rule of Road, E Mark
T85 Headlamps, LH Rule of Road, E Mark
T89 Lamps, Tail & Stop, Export
T90 Lamps, Signaling & Marker, Front, Export
T93 Lamps, Tail & Stop, Special
UD4 Alarm, Vehicle Speed, 120 km/h
UH3 Indicator Low Tire Press, Var 2
UK1 Radio Frequencies, Japanese
UL0 Radio, AM/FM Stereo, Seek/Scan, Auto Reverse Music Search
Cassette, Auto Tone, Clock, Electronically Tuned Receiver (ETR)
UL2 Radio Frequencies, European
UN0 Radio, AM/FM Stereo, Seek/Scan, Compact Disc, Auto Tone,
UV6 Display, Head Up
UV7 Antenna, Windshield, Rear Window, Radio
UZ6 Speaker System 6, Quad Front Door Mounted, Dual Quarter Mounted
U1S Player, Multiple Compact Disc
U19 Instrument Cluster, Speedometer, Metric (Canadian, Export)C5 RPO codes
U52 Instrument Cluster, Electronic
U73 Antenna, Fixed, Radio
U75 Antenna Power, Radio
VD1 Provision Options, Europe
VE1 Provision Options, Japan
VG1 Protector Underhood Compound, Corrosion Preventive, Water Based, Clear
VG8 Vehicle Label, Notice to Buyer
VG9 Protector, Wax, Exterior Body
VH5 Plate, Vehicle Identification
VL4 License Plate Mounting Package, Front, EEC
V49 License Plate Frame
V73 Vehicle Statement, US/Canada
V76 Tow Hooks
V87 Vehicle Statement, Gulf States Organization
XAB Tire Front 245/40ZR17 95Y BW
XFW Tire, Front, P265/40R17 BW R/PE ST TL HW4
XGG Tire, Front, P245/45R17 89Y, BW TL SBR HW4, EMT
XMC Tire, Front, P245/45R17 89Y,BW R/PE ST TL HW4
YAC Tire Rear P245/40ZR18 94Y BW ST TL HW4
YFU Tire, Rear, P295/35R18 91Y, BW R/PE ST TL HW4
YGH Tire, Rear, P275/40R18 94Y,BW TL HW4 SBR, EMT
YME Tire, Rear, P275/40R18 94Y, BW TL HW4 SBR
Z16 Performance Package Z06 Commemorative Edition
Z18 Performance Package European Commemorative Edition
Z49 Modifications, Canadian, Mandatory Base Equipment
Z5X Mirror Provisions, Arabic Language
Z51 Performance Package, Handling
