Conditions in Which Remote Start Will Not Work
The remote start will not operate if any of the following occur:
. The ignition is in any mode other than off.
. A remote key is in the vehicle.
. The hatch/trunk is not closed.
. The convertible top is not fully open or closed.
. The tonneau cover is not closed.
. The hazard warning flashers are on.
. There is an emission control system malfunction.
. The engine coolant temperature is too high.
. The oil pressure is low.
. The 30 minutes of engine run time have been used.
. The vehicle is not in P (Park).
If you have a check engine light illuminated
