Joined: Dec 2000 Posts: 5,871teamzr1 Owner - Pays the bills
Look at the 2023 Z06 Corvette with stock exhaust results at the bottom of this
The Dba even 5 feet back is way over federal law allows and even worse 2 feet away from exhaust tips
I know what loud is in designing my custom exhaust system for my C5 and then a lot of long term testing :
In testing, the sound as to DbC level is too high, average inside the car with windows up is about 110 DB and as much as 128 DbC near the rear wheels.
Measuring as to ear quality levels as DbA inside measured 92 and outside 102 DbA. We want final design under 95 DbA and less than 85 DbA inside.
Important to keep in mind is what levels of sound human ears can take
Types of Hearing Loss
There are many different causes of hearing loss. The following are the general categories into which hearing loss falls:
Otosclerosis - is a disease that causes bony growth on the ossicles and causes the stapes to become immobile, thus not allowing sound to be transferred into the cochlea. This is the result of a disease that affects the movement of the stapes, located in the middle ear.
Meniere's disease - is a problem involving fluid pressure within the cochlea. It causes the sufferer to experience intermittent episodes of hearing loss, dizziness, and tinnitus. These episodes can occur anytime and for varying amounts of time.
They are often associated with stress. Drug induced - some medications can result in damage to the auditory system with prolonged use. They are called ototoxic. Here are a few drugs that are known to cause hearing loss: aminoglycoside antibiotics (such as streptomycin, neomycin, kanamycin); salicylates in large quantities (aspirin), loop diuretics (lasix, ethacrynic acid); and drugs used in chemotherapy regimens (cisplatin, carboplatin, nitrogen mustard).
Tumors - one of the common tumors in the ear is called a vestibular schwannoma. These tumors develop around the 8th cranial nerve, which is also known as the auditory nerve. Trauma - trauma to the ear can include fractures of the temporal bone, puncture of the eardrum by foreign objects, sudden changes in air pressure, and very loud noises.
Presbycusis - this hearing loss is caused by natural aging of the human body and begins after age 20, but often it is not noticed until the ages of 55 to 65. Presbycusis affects the high frequencies in the speech range, making understanding and hearing speech difficult.
Noise-induced hearing loss (NIHL) - this is hearing loss due to exposure to either a sudden, loud noise or exposure to loud noises for a period of time. A dangerous sound is anything that is 85 dB (sound pressure level - SPL) or higher. Dangerous Decibels focuses on noise-induced hearing loss.
Noise-Induced Hearing Loss (NIHL)
Of the roughly 40 million Americans suffering from hearing loss, 10 million can be attributed to noise-induced hearing loss (NIHL). NIHL can be caused by a one-time exposure to loud sound, as well as by repeated exposure to sounds at various loudness levels over an extended period of time.
Damage happens to the microscopic hair cells found inside the cochlea. These cells respond to mechanical sound vibrations by sending an electrical signal to the auditory nerve. Different groups of hair cells are responsible for different frequencies (rate of vibrations). The healthy human ear can hear frequencies ranging from 20Hz to 20,000 Hz. Over time, the hair cell's hair-like stereocilia may get damaged or broken. If enough of them are damaged, hearing loss results. The high frequency area of the cochlea is often damaged by loud sound.
Sound pressure is measured in decibels (dB). Like a temperature scale, the decibel scale goes below zero. The average person can hear sounds down to about 0 dB, the level of rustling leaves. Some people with very good hearing can hear sounds down to -15 dB. If a sound reaches 85 dB or stronger, it can cause permanent damage to your hearing. The amount of time you listen to a sound affects how much damage it will cause. The quieter the sound, the longer you can listen to it safely. If the sound is very quiet, it will not cause damage even if you listen to it for a very long time; however, exposure to some common sounds can cause permanent damage. With extended exposure, noises that reach a decibel level of 85 can cause permanent damage to the hair cells in the inner ear, leading to hearing loss. Many common sounds may be louder than you think…
A typical conversation occurs at 60 dB - not loud enough to cause damage. A bulldozer that is idling (note that this is idling, not actively bulldozing) is loud enough at 85 dB that it can cause permanent damage after only 1 work day (8 hours).
When listening to music on earphones at a standard volume level 5, the sound generated reaches a level of 100 dB, loud enough to cause permanent damage after just 15 minutes per day! A clap of thunder from a nearby storm (120 dB) or a gunshot (140-190 dB, depending on weapon), can both cause immediate damage.
In fact, noise is probably the most common occupational hazard facing people today. It is estimated that as many as 30 million Americans are exposed to potentially harmful sounds at work.
Even outside of work, many people participate in recreational activities that can produce harmful noise (musical concerts, use of power tools, etc.). Sixty million Americans own firearms, and many people do not use appropriate hearing protection devices.
Decibel Exposure Time Guidelines
Accepted standards for recommended permissible exposure time for continuous time weighted average noise, according to NIOSH and CDC, 2002. For every 3 dBs over 85dB, the permissible exposure time before possible damage can occur is cut in half.
Continuous dB Permissible Exposure Time
85 db 8 hours 88 dB 4 hours 91 db 2 hours 94 db 1 hour 97 db 30 minutes 100 db 15 minutes 103 db 7.5 minutes 106 dB 3.75 min (< 4min) 109 dB 1.875 min (< 2min) 112 dB .9375 min (~1 min) 115 dB .46875 min (~30 sec)
2023 stock Z06 dBA readings while parked
#5851 - 11/28/2202:41 PMRe: C8 Z06 is a LOUD Bitch
[Re: teamzr1]
The all-new Corvette Z06 needed an air-piercing sound to match its performance and design. Here’s how engineers dialed in the perfect roar.
The roar of a high-performance sports car is visceral. So, when Chevrolet created the 2023 Corvette Z06 with the most powerful naturally aspirated production V8 ever 670 horsepower and an 8600-rpm redline they wanted the sound to be just as powerful.
That’s why Aaron Link, Corvette lead development engineer, and members of the project team devoted so much effort to perfecting the sound of the Z06, ensuring drivers can fully enjoy the power of the 5.5-liter dual overhead cam engine.
The Corvette’s traditional small-block V8 is known for its booming, bass-heavy sound, Link says. But the new engine, employing a flat-plane crankshaft, has an elemental scream. “The firing order of a flat-plane crankshaft engine inherently puts it in a different ‘sound category’ than our small-block Chevy.
Even if we wanted to make this car sound like previous Corvette Z06s, physics obstructs it. So we embraced the fact that this was always going to be a new chapter in Corvette’s rich sound history, and I am confident it’s one for the ages,” Link says.
Everyone has a different idea of the perfect sound, but the Z06 team agreed on the same basic qualities. “We wanted a sound that could be felt, not just heard. One that pierced the air and carried on well after the car was seen, regardless of wind direction or where we were standing or tree cover,” Link says, “where I could close my eyes and hear it for miles.”
He says a flat-plane engine typically can produce an undesirable buzz sound that has to be minimized. The solution: two sets of exhaust tips next to each other in the middle of the car’s rear fascia. The resulting sound waves cancel each other out, eliminating the buzz. The Z06 team also wanted to minimize what Link calls “air rush,” that jet engine–like tone usually caused by turbulence in a muffler with sharp angles. So, engineers designed a muffler with smoother bends and very short pipes.
Next, they expanded the pipe diameter of 2-3/4 inches to 3 inches. “That gives the sound waves more space and less back pressure to pass through a pipe,” Link says. The higher-pitched sound of a flat-plane V8 at higher engine speeds and, again, the Z06 redlines at an outrageous 8600 rpm is what this car shines at, and the team intently focused upon making the experience rewarding and memorable through sound.
Design done, the Z06 engineers turned to extensive testing and tweaking, including one last change to the exhaust’s internal baffle plates after team members noticed the sound “had lost some of its brilliance,” Link says. Link knew the project was a success last summer when he saw video footage of the Z06 on a test run in Germany. You could still hear the car miles away from the filming site. They scored the distinct sound they needed, one that Link says “leaves no doubt this is a different beast altogether.”
