Bulletins for 1984 Chevrolet Corvette V8-350 5.7L
Safety Recalls
TSB Number Issue Date TSB Title
1. 84C25 SEP 85 Axle (Rear) - Differential Cross Shaft/Revised Info
2. 84C22 MAR 85 Product Safety Campaign 84C22 Relocation of Cruise Control Serv
3. 84C02 JUN 83 Front Brake Caliper Bracket Bolt
Service Bulletins
1. 99-00-89-022 DEC 99 The Year 2000 and Vehicle Electronics
2. 99-00-84-021 NOV 99 Expediting Parts
3. 99-08-42-009 NOV 99 Setting of I/P Dimmer Control to View PRNDL Display
4. 99-06-02-017 OCT 99 Radiator Repair/Replacement Guidelines
5. 99-08-51-007 OCT 99 Refinishing Aluminum Wheel
6. 99-00-89-019 OCT 99 Warranty Parts Center/Corporate Parts Return Program
7. 99-00-01-001 SEP 99 AC Delco Remanufactured Engines
8. 99-07-30-017 SEP 99 Auto/Trans Oil Cooler Flushing and Flow Check Procedures
9. 99-07-30-020 SEP 99 Automatic Transmission Service Procedure Change
10. 99-08-64-016 SEP 99 Use of Silicone for Weatherstrip Maintenance
11. 000000A JUL 99 GM Service Bulletin Precautions
12. 99-03-10-102 JUN 99 Original Equipment Chrome Plated Aluminum Wheel ID
13. 99-08-49-006 APR 99 Cleaning of Upper Instrument Panel Surfaces
14. 99-08-51-001 APR 99 Paint-less Dent Repair Process
15. 99-06-03-002 MAR 99 Battery Insulator Replacement
16. 83-81-34 MAR 99 Operating Vehicle with SIR Warning Light On
17. 99-00-89-002 MAR 99 Using the New GM Service Bulletins
18. 86-05-02 DEC 98 Delayed Warranty Start Process
19. 87-71-74 NOV 98 1-2 Accumulator Piston and Outer Spring Replacement
20. 83-35-08 NOV 98 Chemical Staining of Chrome Wheels
21. 76-02-02A OCT 98 Recommended Axle Lubricant
22. 80-05-03 AUG 98 Redefined Use of Parts Warranty Special Claims B and C
23. 82-05-03 MAY 98 Elimination of Labor Op Z7920/Z7930
24. 82-05-02 MAY 98 Request for Authorization Using Routing Code H
25. 87-61-24 APR 98 Use of Surface Conditioning Discs
26. 83-01-14 MAR 98 VIN Plate Replacement
27. 72-05-09 FEB 98 GM Dealer Empowerment Program
28. 82-05-01 FEB 98 New Vehicle / Replacement Battery Warranty Instructions
29. 73-50-37 JAN 98 Brake Rotor and Hub Cleaning Tool Revision
30. 72-05-14 JAN 98 Enhanced Sublet Repair Policy
31. 72-05-13 JAN 98 Repair/Replace Policies and Procedures
32. 72-05-12 JAN 98 Shock Absorbers and Struts Operations
33. 72-05-07 DEC 97 ACDelco Remanufactured Engines
34. 72-05-11 DEC 97 Rail Dust Removal and Chemical Spotting - labor
35. 71-05-02 DEC 97 Recall Campaign Follow-Up Post Card
36. 73-01-10 DEC 97 Technical Assistance Call Preparation
37. 62-05-02A NOV 97 Labor Operation Z1241 - Personal Property Damage
38. 73-12-13 NOV 97 PureGuard 2 Operating Alert
39. 73-62-13A SEP 97 Servicing of Aluminum Heater Cores and/or Radiators
40. 72-05-02 AUG 97 AC Delco Remanufactured Transmissions
41. 73-62-13 JUL 97 Aluminum Heater Core and/or Radiator Replacements
42. 73-62-14 JUL 97 Approved Engine Coolant Recycling Processes
43. 73-10-54 MAY 97 Two-Part Urethane Adhesive For Windshield Installations
44. 631208A APR 97 A/C Tool And Equipment Maintenance
45. 620504 APR 97 Operating Procedures
46. 731204 FEB 97 Air Conditioning Systems With R12 Or R134a Service Issue
47. 731049 FEB 97 Body Sealer Tape For Collision Repairs
48. 649601 JAN 97 Compact Disk Players Procedures
49. 431207E JAN 97 Guidelines For Retrofit R-12 Vehicles To R-134a
50. 600503 JAN 97 Warranty Repairs And Claims Procedures
51. 62-05-03 DEC 96 Dealer Prohibited Use of Labor Open. and/or Claim Type
52. 310503C DEC 96 Warranty Claim Processing
53. 610111 NOV 96 Key Code Information
54. 668304A SEP 96 ACDelco Service Center Locations Odometer/Speedometer
55. 400501A SEP 96 Corporate Parts Return Program Instructions
56. 636532 MAY 96 Enhanced Emission Inspection Maintenance - Equipment
57. ATRATB334 JAN 96 Delayed Forward Engagement / Burnt 3-4 Clutches
58. ATRATB256A JAN 96 Rear Planet Failure - Lack Of Lube
59. 516547 JAN 96 Revised Tech 1 Cartridge for Oxygen Sensor Test
60. 536507 DEC 95 Enhanced Emission Inspection Maintenance - Update
61. 588302A JUL 95 AC Delco Locator Service for Delco Electronics Exchange
62. 570102 JUN 95 Reformulated, Oxygenated Gasoline and Calif. Phase 2 RFG
63. 580101 JUN 95 Use of a Diagnostic Worksheet
64. 531205 MAY 95 Contaminated R12 Refrigerant Testing & Handling
65. 436201B APR 95 Propylene Glycol Engine Coolant
66. 570201 MAR 95 General Information - Dexron® III A/T Fluid Introduction
67. 431218A MAR 95 J 39400 A/C Leak Detector Maintenance Kit Availability
68. 420515A FEB 95 Chevrolet Claim Processing
69. 516502 FEB 95 I/M Emissions Diagnostic Manual
70. ATRATB294 JAN 95 Axle Nut/ Lug Nut Tightening Specifications
71. 436510 JAN 95 I/M 240 Program - Equipment Purchase
72. ATRATB292 JAN 95 No 2nd, No 4th and No TCC - 700-R4
73. 436507 DEC 94 Enhanced Emission Inspection Maintenance Program
74. 435009 DEC 94 Front Brake Pulsation - New Diagnosis and Repair
75. 431048 NOV 94 Adhesive Caulking Kit Revisions
76. 436506 OCT 94 I/M 240 Repairs - Obtaining Technical Assistance
77. 446501 OCT 94 PROM/MEMCAL - Identification Marks
78. 431223 SEP 94 Contaminated A/C Refrigerant
79. 410103 SEP 94 Product Campaign Bulletin Numbering System
80. 330105A SEP 94 Using GM Service Bulletins
81. 149301 JUL 94 Release of Service Package For Nickel Tape
82. 433502 JUL 94 Speed Rated Tires
83. 436505 APR 94 Enhanced Emission Inspection Maintenance Programs
84. 033206 MAR 94 Reduced Power Steering Assist (Cold)
85. 435001 FEB 94 Aftermarket Anti-Lock Brake System Products
86. 310504 FEB 94 Policy - Recycled Engine Coolant
87. ATRATB234 JAN 94 Forward Sprag Design - 700-R4
88. ATRATB265 JAN 94 Rear Planet Failure (Lack of Lube) 700-R4
89. 331226 JAN 94 Retrofitting R-12 Vehicles to R-134A
90. ATRATB201 DEC 93 No Line Pressure Rise - Stuck Pump Slide
91. ATRATB196 DEC 93 Shifts In Manual Low - 700-R4
92. 383001 DEC 93 Steering System Bleed Procedures
93. 306502 OCT 93 How Fuel Economy Is Determined
94. ATRATB179 JUL 93 Late Or No Upshifts
95. 393504 JUL 93 Leaking Cast Aluminum Wheels
96. ATRATB175 JUL 93 No 2nd Gear
97. 349212R JUL 93 Radio Frequency Interference - Identification/Diagnosis
98. 316501R JUN 93 Introduction Of The Fuel Injector Tester Tool
99. 931638A MAY 93 Isolation Diodes Information
100. 9313310 MAR 93 Door Locks Binding or Sticking/Key Hard to Insert
101. 9313110 MAR 93 Rear Lift Window Hard to Open/Hinge Loose to Glass
102. 9358A10 FEB 93 Acid Rain and Rail Dust Damage to Base/Clear Coat
103. 93966C FEB 93 Factors That Affect Fuel Economy
104. 939710 FEB 93 Paint Peeling From Muffler
105. 93774B JAN 93 Differential Pinion Shaft Lock Screw
106. ATRATB134 NOV 92 Bind In Reverse - 700R4
107. 93297A OCT 92 Buzzing Noise At Idle Coming From the 4L60E A/T
108. 93316C OCT 92 Effect of Fuel Volatility On Driveability
109. 93356D OCT 92 Engine Miss, Hesitation or Roughness - Information
110. 93203E OCT 92 Scuff/Scratch Removal From Aluminum Wheels
111. 922501A AUG 92 Use of Alternate Refrigerants In CFC 12
112. 922323E JUN 92 Damage Due to Improper Mounting of Steel Wheels
113. ATRATB118 JUN 92 Valve Body Interchange - 700R4
114. 923310 NOV 91 Acid Rain Damage to Base Coat/Clear Coat
115. ATRATB078 NOV 91 How To Use A Pressure Gauge - Automatic Trans.
116. 92427A NOV 91 Sporadic Transmission Slip, Downshift, or Busy Cycling TCC
117. 913880A AUG 91 A/C Delco Advance Exchange Programs
118. 913846E AUG 91 Damaged and/or Misdiagnosed ECM/PCM
119. 913967A AUG 91 Evaluating Peened Spacer Plates On All A/T
120. 913907A AUG 91 New Output Shafts and Seal
121. 913717A JUL 91 4L60/700-R4 Transmissions Stuck In First
122. ATRATB058 JUL 91 Valve Body Assembly 700-R4 Inspection
123. 913446E JUN 91 State Emissions Testing Information
124. 9133410 MAY 91 Hvlp-High Volume Low Pressure Paint Application
125. 912980A MAY 91 Labor Time Guide Request For Review Updates
126. 912837A APR 91 Automatic Transmission Binding In Reverse Condition
127. 912850A APR 91 Cleaning of Upper Instrument Panel Surfaces
128. ATRATB046 APR 91 Diagnosing Converter Lock-Up Problems
129. 9128210 APR 91 Importance of Checking Clear Coat Thickness
130. 912841A APR 91 Loose or Missing A/C Access Fitting Caps
131. 9041210 MAR 91 Inoperative Power Seat and/or Blows Fuse
132. 873098B MAR 91 Kit For Headlamp Door Actuator
133. ATRATB043 MAR 91 No 4th, Late 4th, Falls Out Of 4th - 700-R4
134. 912356B MAR 91 Use of Recycled Engine Coolant
135. 912136D FEB 91 Parasitic Current Drain Procedure, No Start Condition
136. 912083B FEB 91 Reduced Power Steering Assist At Low Temperatures
137. ATRATB030 DEC 90 Bind-Up On The 1-2 or 3-2 Downshift
138. 911335 DEC 90 Change In Brake Feel After Rotor Refinishing
139. 911268E NOV 90 Chattering Wiper Blades
140. 903727A OCT 90 4L60 Service Replacement Model Update
141. ATRATB028 OCT 90 Engine Testing With A Vacuum Gauge - Auto Trans.
142. 91858A OCT 90 Procedure For Checking Connector Terminal Contact
143. ATRATB024 SEP 90 Harsh Reverse Engagements
144. ATRATB010 SEP 90 Torque Converter Identification
145. 902935 JUL 90 Brake Lathe Produces Poor Brake Rotor Finish
146. 902488B MAY 90 Underhood Lamps Are Inoperative or Stay On
147. 91108A APR 90 Aftermarket Accessories Installation Guidelines
148. 91148A APR 90 Checking For Parasitic Current Drain
149. 902166 APR 90 Prevent Leakage of Small 75 mm Oil Filters
150. 91090A APR 90 Used Anti-Freeze Policy
151. 901996E MAR 90 Revised Chart C-1D, Code 33, 34, 63, 64
152. ATRATB9002006 FEB 90 Automatic Transmission Fluid
153. 901627A FEB 90 New Rear Bushing Removal/Installation Procedure
154. 9015410 FEB 90 Seat Cushion Retainer Wire Service Kit
155. ATRATB9001003 JAN 90 Lubrication Correction - 700R4
156. 909210 NOV 89 Carpet Inserts Become Loose
157. ATRATB8930 OCT 89 Automatic Transmission Math Part 2
158. 90753E OCT 89 Tire Company Warranty Assistance Programs
159. 892680B OCT 89 Use of Gasoline Containing 15 Percent Mtbe
160. ATRATB8927 SEP 89 20 Steps To successful Auto Transmission Repair
161. 892531B SEP 89 CFC Reduction and Refrigerant Recovery Recycling
162. ATRATB8928 SEP 89 Fluid Filter Seal
163. 892625 SEP 89 Light Brake Drag - Brake Switch Adjustment
164. 90568 SEP 89 Packard 32 Way Connector Identification
165. 892583B SEP 89 Steering Gear Intermediate Shaft Torque Specifications
166. ATRATB8923 AUG 89 Automatic Transmission Math Formulas
167. 90496B AUG 89 Reconstituted Anti-Freeze
168. ATRATB8926 JUL 89 ATM Wiring Diagrams Thru 1989 - 700R4
169. 90340A JUL 89 Labor Guide Request For Changes, Feb./June
170. 892037A JUL 89 Proper Usage of Spacer Plate Gaskets In Overhaul Kit
171. ATRATB8921 JUL 89 TCC Lock-Up Delay Valve - 700R4
172. 891976A JUN 89 Camshaft Specifications, Manual Revision
173. ATRASIL8917 MAY 89 New Control Valve Assembly - 700R4
174. 891528B MAY 89 Selection of Correct Wire Insulation Material For Wire Repairs
175. 891271B APR 89 A/C Refrigerant Loss Due to Loose or Missing Access Fitting Cap
176. 891460A APR 89 Goodwrench® Vehicle Security System Labor Operations
177. 891386A APR 89 Revised Procedure - Install or Connect Intake Manifold
178. 891126C MAR 89 Fuel Pump Strainer (In-Tank Filter/Sock) Replacement
179. 891167A MAR 89 New Case Assembly - Removal of 2ND, 3RD, and 4TH Clutch Pressur
180. 891089A MAR 89 Poor AM or FM Radio Reception
181. 89970A MAR 89 Use of Car/Truck Line Indicator In Place of Model Names
182. ATRASIL895 FEB 89 Improved Governor Driven Gear
183. 89900A FEB 89 Labor Time Guide Request For Review Changes - September/January
184. ATRATB894 FEB 89 New Fluid Filter Seal
185. 89855 FEB 89 On-Car Brake Rotor Turning Tool
186. 89593E JAN 89 Cast Aluminim Wheel Porosity
187. 89637A JAN 89 New Control Valve Assembly Elimination of TCC Bore
188. 89316C NOV 88 Fuel Feed and/or Return Pipe Repair
189. ATRATB8847 NOV 88 Kills Engine In Drive And/Or Reverse - TCC Problem
190. 8836510 NOV 88 Media Blasting Sources
191. 8836710 NOV 88 Rusting Fuel Filler Door Hinge Links and Pins
192. 89381B NOV 88 V5 Air Conditioning and Refrigerant System Diagnostic Procedure
193. 883517B OCT 88 Neutral/Drive Manual Transmission Gear Rattle
194. 883405 SEP 88 Disk Brake Noise
195. 883450A SEP 88 Rear Seat Lap/Shoulder Belt Kits
196. 89013A SEP 88 The Importance of Four Wheel Alignment
197. ATRATB8836 AUG 88 Bind Up When Overdrive Is Engaged
198. 883125 AUG 88 Brake Pulsations and Disc Brake Rotor Surface Refinish
199. 882836E JUL 88 Electrostatic Discharge Damage
200. ATRATB8834 JUL 88 Identifying Correct Sprag Rotation - Auto Transmission
201. 8824210 JUN 88 Cleaning of Upper Instrument Panel Surfaces
202. 882456B JUN 88 Engine Cooling System Leaks
203. 882463E JUN 88 Installation of After Market Styled Wheels
204. 872959A JUN 88 Radio Noise "Pop" Caused By Switches
205. 882696E JUN 88 Rough, Unstable or Incorrect Idle Service Manual Update
206. 8826310 JUN 88 Six-Way Power Seat Adjusters
207. 8729210 MAY 88 Painting Procedures
208. ATRATB8822 MAY 88 Solid Teflon® Sealing Rings/Turbine Shaft - 700R4
209. 882077A MAY 88 Sporadic Engagement of Torque Converter Clutch
210. ATRASIL8813 MAR 88 New 3-4 Clutch Apply Package - 700R4
211. ATRATB8816 MAR 88 No Upshift - Governor Contamination
212. ATRATB887 FEB 88 Checking Pressure Switches For Leaks
213. ATRASIL8810 FEB 88 New Lo And Reverse Clutch Assembly - 700R4
214. 8726310 JAN 88 Front Center Air Deflector Damage
215. ATRASIL881 JAN 88 New Iron Pump Rings
216. 8726810 JAN 88 Window Regulator Replacement
217. ATRATB8770 DEC 87 No Passing Gear (forced detent) Upshifts Normal
218. ATRASIL8732 OCT 87 Fluid Leaks/Oil Pump Body Seal - 700R4
219. 87224 OCT 87 Rattle From Turn Signal Lever
220. ATRATB8754 SEP 87 All Automatics - Front Bushing Wear
221. 8856 SEP 87 New Pump Assembly Vane Rings THM 700-R4 THM 200-4R
222. 8842 SEP 87 Service Replacement Electronic Modules (ECM) With PROM Installe
223. ATRASILEXTRA AUG 87 Correction To Service Bulletin
224. ATRATB8748 AUG 87 Metal Sealing Rings - Automatic Transmissions
225. ATRASIL8722 JUL 87 Correction To SIL8722 - 700R4
226. ATRASIL8722 JUL 87 Pump Assembly - Casting Number Information 700R4
227. ATRATB8735 JUN 87 4-3 Downshift/Slight Acceleration - 700R4
228. ATRATB8736 JUN 87 Restricted Exhaust System Check
229. ATRATBEXTRA JUN 87 Service Bulletin Correction - 700R4
230. 87150 MAY 87 Revised ECM Replacement Procedure - Chart C-1
231. ATRASIL8713 APR 87 Auxiliary Accumulator Valve - 700R4
232. 87116 APR 87 Loose Corvette Door Trim Panel
233. 86237 APR 87 Power Steering Fluid Cooler
234. ATRATB8725 APR 87 Updated Input Sprag Assembly - 700R4
235. ATRASIL878 MAR 87 Converter Clutch Solenoid - Fluid Source Identification
236. ATRASIL8710 MAR 87 Down-Shift Clunk In Manual -3- Range - 700R4
237. 8786 MAR 87 Power Seat Transmission Usage and Identification
238. 862226C FEB 87 Engine Surge After A Hot Soak and Short Park
239. 86220 FEB 87 Slipping/Loss of Drive Range THM 700-R4
240. 85219 FEB 87 Upper Quarter Panel Removal and Installation Procedure For Crac
241. ATRATB876 JAN 87 2-3 Flare-up, or Repeated 3-4 Clutch Failure
242. ATRASIL871 JAN 87 Checking Lubrication Passages - 700R4
243. 8758 JAN 87 Transparent Removable Roof Panel Breakage
244. ATRATB8662 DEC 86 Clunk on 2-3 Shift - 700R4
245. ATRATB8661 DEC 86 Diagnosing Internal Pressure Leaks - 700R4
246. 84270 NOV 86 Coolant Sensor Kit
247. ATRASIL8627 NOV 86 Service Procedures - Oil Pump
248. ATRASIL8614A OCT 86 Correction To Service Bulletin - 8614
249. 86185 OCT 86 Corvette Body Repair Materials
250. 86176 OCT 86 Electric Outside Rear View Mirrors
251. 86188 OCT 86 Fluid Leaks From the Oil Pump Body Seal
252. ATRATB8648 SEP 86 Case Switches Installed On Outside Of Case - 700R4
253. 86148 SEP 86 New Accumulator Pistons and Seals For Enhanced Shift Points and
254. ATRASIL8619 SEP 86 Overheating In Fourth Gear
255. ATRATB8647 SEP 86 Partial Tie Up In Reverse - 700R4
256. ATRASIL8620 SEP 86 Production Changes 1984 - 700R4
257. ATRATB8642 AUG 86 Blowing Fuses, Engine Runs Bad; No TCC Lock-Up
258. 86124 JUL 86 1982-1986 THM 700-R4 Transmissions Slipping Condition-Loss of D
259. ATRASIL8613 JUL 86 Harsh 1-2 Shift - 700R4
260. 86117 JUL 86 Power Seat Adjuster-Excessive Movement
261. ATRATB8634 JUL 86 Pressure Tap Locations - Automatic Transmissions
262. 86107 JUL 86 Rear Axle Service Parts Usage and Identification
263. 84265 JUL 86 Rear Hatch Window Assist Rods
264. ATRASIL8614 JUL 86 Shudder In Reverse Condition - 700R4
265. 8696 JUN 86 1982-1986 THM 700-R4 Transmissions New Pump to Case Bolt and O-
266. ATRATB8627 JUN 86 Late Upshifts/High Main Line Pressure - 700R4
267. ATRATB8628 JUN 86 Low Mainline Oil Pressure - 700R4
268. ATRATB8632 JUN 86 Manual Valve Sticks - 700R4
269. ATRASIL8612 JUN 86 Oil Pressure Switch Locations - 700R4
270. ATRATB8630 JUN 86 Passing Gear Spin-Up/Engine Revs Up - 700R4
271. ATRATB8624 JUN 86 Pump Failure
272. ATRATB8633 JUN 86 Reverse Friction (Lined) Clutches - 700R4
273. ATRASIL8611 JUN 86 Service Update - 700R4
274. ATRATB8629 JUN 86 Snap Ring Jumps Out Of Place - 700R4
275. ATRATB8623 MAY 86 Hidden Residue Build Up - Valves Sticking
276. 8662 APR 86 Uneven Wear-Outer Ribs On Corvette Tires
277. 86477C MAR 86 700-R4 Transmission Shudder In Reverse Condition
278. ATRATB8612 MAR 86 Converter Clutch Shudder
279. ATRATB8614 MAR 86 TCC Lock-Up Kits 700R4 - Precautions
280. 8652 MAR 86 THM 700-R4 Transmissions - Manual Update For Elimination of the
281. 8651 FEB 86 All THM Transmissions-Identification Information, Including 3-L
282. ATRATB8610 FEB 86 Pump Break Up - Excessive Regulator Shuffle
283. 8636 FEB 86 Remanufactured Fuel Injectors For (TBI) Throttle Body Injection
284. ATRATB861 JAN 86 Rapid Pump Bushing Wear
285. ATRATB863 JAN 86 Sticking Throttle Valves
286. 8617 JAN 86 Window Regulators
287. 8615 DEC 85 Locks Cylinders - Inoperative/Proper Lubricant Usage
288. 85157 NOV 85 Air Conditioning - DA6 Compressor Assembly Info
289. 85146 NOV 85 Cruise Control (Custom III) - Delay - Misdiagnosed
290. 868 NOV 85 Fuel System - Integrator/Block Learn - Fuel Delivery
291. 85136 OCT 85 Door - Trim Panel Upper Garnish Molding - Available
292. 85111 AUG 85 4 Speed - Direct Drive - Noise/All Gears (AOD)
293. 85107 JUL 85 THM 700-R4 - New Pump Assembly - Service Parts Info
294. 85100 JUL 85 TV Cable - Identification (700-R4 Light Duty)
295. 8568 APR 85 4 SPD - Loss of AOD Operation - Condition Correction
296. 84252 APR 85 Defogger (Rear Hatch) - Blown Fuses/Circuit Revision
297. 85626CVIM APR 85 Driveability Conditions - Excessive Alcohol In Fuel
298. 8561 APR 85 P/S - Rack & Pinion - O-Ring Seal Fitting Leaks
299. 8570 APR 85 Seat Belts - Mandatory Legislation & Extenders
300. 8571 APR 85 THM 700-R4 - Control Valve Assembly - Proper ID
301. 8563 APR 85 THM 700-R4 - Forward Clutch Plate Assembly
302. 8559 MAR 85 Basecoat/Clearcoat Repair Systems
303. 85546VI MAR 85 Minimum Acceptable Oil Levels - Updated
304. 8548 MAR 85 Oil Seal Leak - AOD - Output Shaft & Pump Assembly
305. 8547 MAR 85 Paint - Repair Without Repainting - Procedure
306. 8555 MAR 85 Rear Hatch Window - Trim Panel (Rear)/Rubber Bumper
307. 8540 FEB 85 A/C - Refrigerant Hose & Clamp Repairs
308. 8538 FEB 85 Brakes - Caliper/Knuckle Assemblies - Clearance
309. 8543 FEB 85 Door Ajar Light - Inoperative - Switch Corrosion
310. 84240 FEB 85 Engine Stops When Starting With A/C "On" (A/T)
311. 8533 FEB 85 Rack & Pinion Steering "Short Gear" (RWD) Available
312. 8535 FEB 85 Replacement of the Pump Body Oil Seal Assembly
313. 8536 FEB 85 THM/ATX-Hex Head Screws & Conical Washer Assemblies
314. 84235 FEB 85 Throttle Position Sensor Specifications
315. 8531 FEB 85 Transmission Damage - Roll Pin Not Seated Fully
316. 8537 FEB 85 Wheel Nuts (Locking) - Replacement Procedure
317. 8528 FEB 85 Wheels - Tight Fitting - Procedure For Removing
318. ATRASIL8530 JAN 85 2nd Apply Piston & Housing Applications - 700R4
319. 84232 JAN 85 Brake Pads - Hold-Down Spring Breakage - Replacement
320. ATRATB8514 JAN 85 Erratic/Late Shifts As Unit Gets Hot - 700R4
321. ATRASIL8532 JAN 85 Front Pump - Air Check 700R4
322. 84151 JAN 85 Generator - Noise (Moan) - At Idle With A/C On
323. ATRATB856 JAN 85 Lip Seal Packages - Part Numbers
324. ATRASIL8515 JAN 85 Model/Converter Identification - 700R4
325. ATRATB8524 JAN 85 No Converter Clutch Apply When Unit Is Hot
326. ATRATB8523 JAN 85 No Drive/Reverse/Third Gear Or Fourth Gear
327. ATRATB8517 JAN 85 No Upshift, Good Reverse and Drive - 700R4
328. ATRATB8529 JAN 85 No-Reverse, Shudder, Or Delayed Reverse - 700R4
329. ATRATB8520 JAN 85 Occasional No-Reverse, Or Shudder In Reverse
330. ATRASIL853 JAN 85 Pump Assembly - Part Numbers
331. ATRATB8513 JAN 85 Pump Cover Screen - 700R4
332. ATRATB8543 JAN 85 Recurrent Sticking Valves - Automatic Transmission
333. ATRATB8521 JAN 85 Sleeving Governor Bore - 700R4
334. ATRASIL8526 JAN 85 Solenoid Reference Chart - 700R4
335. ATRASIL8524 JAN 85 Updated Input Shaft/Pump/Converter - 700R4
336. ATRASIL8535 JAN 85 Updated Oil Pump - 700R4
337. ATRASIL8531 JAN 85 Updated Pinion Carrier - 700R4
338. ATRATB8545 JAN 85 Valve Chatter/Not Enough Oil Feed - 700R4
339. 8526 JAN 85 Wire Wheel Cover - Noisy At Low Speeds - Repair
340. 8517 DEC 84 Add/On (Auxiliary) Electrical Equipment Installations
341. 84222 DEC 84 Power Window Regulator Assembly Special Policy Adjustment Bulle
342. 84226 DEC 84 Radio Ignition Noise
343. 84225 DEC 84 Replacement Brake Pad Usage
344. 84223 DEC 84 Ride Harshness Z-51 Suspension
345. 8512 NOV 84 Fuel Line "O" Rings
346. 841676 OCT 84 "Add On" of Electrical or Vacuum Operated Equipment
347. 8483 OCT 84 A/C Compressor Shaft Seal Usage
348. 855 OCT 84 Burned 3-4 Clutch and/or High 2-3 Shifts
349. 84198 OCT 84 Engine Overheating
350. 84208 OCT 84 Low Speed - "Chuggle"
351. 84200 OCT 84 Stabilizer Bar Link Attaching Nut
352. 84213 OCT 84 Transmission Maintenance Information - Four-Speed Manual Transm
353. 84191 SEP 84 Automatic Transmission Identification Information
354. 84180 AUG 84 Engine Oil Level Operating Range
355. 84179 AUG 84 Harsh 1-2 Upshift
356. 84177 JUL 84 Burned Overrun Clutch, Forward Clutch, and 3-4 Clutch Plate Ass
357. 84159 JUL 84 Cleaning and Lubricating Power Antenna Mast Sections
358. 84176 JUL 84 Rear Tie Rods
359. 841607AVII JUL 84 Revised Flywheel Bolt Torque
360. 84162 JUL 84 Slips In Reverse (Burned LO and Reverse Clutch Plates)
361. 84161 JUL 84 Trouble Shooting Hints On 1984 Custom Cruise III (K34)
362. 84141 JUN 84 Brake Squeal
363. 84150 JUN 84 Dead Battery or No Crank After Overnight Set
364. 84144 JUN 84 Elimination of 4-3 Downshift Switch to Reduce Possible 4-3 Down
365. 84149VICLONE JUN 84 Loss of Engine Oil Pressure After Oil Change - Gas Engine
366. 8467 JUN 84 Outside Rear View Mirror "Loss of Adjustment"
367. 84626AVI JUN 84 Rocker Cover Oil Leaks On Small Block V8 or 90~ V6 Engines
368. 84148 JUN 84 Transmission Oil Exhausting Out the Vent Pipe
369. 84127 MAY 84 Cleaning, Painting, and Coating of Aluminum Wheels
370. 84121 MAY 84 Dealer Installed Anchor For Child Seat With Top Strap Anchor In
371. 84130 MAY 84 Engine Oil Cooler Leaks
372. 84113 APR 84 Brake System Service Information
373. 84102 APR 84 Chattering Windshield Wiper Blades and/or Uneven Wipe
374. 84103 APR 84 Checking Pinion Washer For Possible Wear
375. 84117 APR 84 New Input Housing and Shaft Assembly
376. 84112 APR 84 Roof Panel Attaching Plate Repair
377. 84108 APR 84 Service Procedure For the Oil Pump Rotor and Slide
378. 84118 APR 84 Side Door Lateral Movement
379. 8485 MAR 84 Anti-Chip Coatings
380. 8489 MAR 84 Engine Oil Recommendations
381. 8486 MAR 84 Grinding Noise In All Ranges or No Drive Condition On THM 700-R
382. 8461 MAR 84 Transmission Oil Exhausting Out the Breather On Vehicles With 7
383. 8464 FEB 84 1984 Corvettes Painted With 1986 Colors For General Managers CO
384. 8460 FEB 84 Half-Shaft and Propshaft Clinking Noise
385. 83I115 FEB 84 New 2-4 Servo Cover and Seal
386. 8469 FEB 84 Oil Pan Leaks On THM 700-R4 Transmissions
387. 8468 FEB 84 Partial Forward Clutch and/or Band Apply In Reverse Gear On THM
388. 83122 FEB 84 RTV Sealer and Gasket Eliminator
389. 8474
